Everyone please read and help quick
mooser
273 Commando Kid
San Jose, California
Do I need to change the steering center link from a slant six car when installing a 318 (oil pan clearance)? Also will a '72 link fit a '74?
BTW I have a 74 duster and a 72 dart parts car
You will need a small block drop center link to clear. The S/6 ones are strate and will not clear the pan. I think this is correct but mabby some one who has done this swap befor will chime in to help you out.
Good luck with your build.
It should be the same center link with a slight drop in it even if its a slant 6 cars. The earlier A's are the ones that need the swap usually.
Sounds right to me to ,No don't change , the center link you have will work in your 74
to swap a v8 in.
As others have said I believe the center link is the same. I put a 73 /6 in my 66 Dart once and had to put my old oil pan on to make it fit. The 73 was a deeper pan. So I think you will have no problems.
