gerrys
I'm currently in the process of installing a 5.7l into my '69 Dart and since I needed to add a electric pump I decided to put it in the tank like the Durango that I 'harvested' the engine from.
This car is a daily driver so I wanted the install to be as unobtrusive as possible (no mods to the trunk!). I made up this assembly to install it into the existing sender hole. I'll still need to add an external regulator (with a return line) near the tank, but will only need a single 3/8" fuel line to the engine.
