jimmyray
- Joined
- Jul 17, 2007
- Messages
- 951
- Reaction score
- 31
My engine combo:
408 cast crank stroker from Hughes
9.6:1 compression
93 Octane gas
mild port/polish on Edelnbrock al perf heads, closed chamber, fresh valve job
M1 single plane airgap with gasket match (heads too)
Holley 750 DP with proform center section, jetted 74/84, 3.5 power valve
Comp roller .544/.541 236/242 110 centerline
FBO ignition, ditributor curved to 16 inital, 34 total @ 2900 rpm
Hooker comp 1 5/8" headers (dented bottoms on driver side, naturally) 3" collector
3" pipes into/out of welded Summit 3" mufflers into a-body tips
3000 stall TCI streetmaster
727 manual reverse
3.73 sure grip in a narrowed Dana
28 slicks, 27.8 inch street tires
My best time thus far with the combo on slicks is 12.26 @ 109.59
I noticed my last trip out that hitting the lights aroun 107-109 mph was tripping the shift light which is set for 5500 rpm, but my calculations are that it should be revving around 4900. What I've noticed thus far (see attachment below)
So, I think this is too much slippage. I plan on calling Dynamic convertor next week. The Converter I have was recently rebuilt by PTC, and they fixed several issues, but...
Thoughts?
9.6:1 compression
93 Octane gas
727 manual reverse
Thoughts?
