MopaR&D
Nerd Member
I just got a set of dual valve springs w/dampers for my 318 and the valve stem seals that came in my Fel-Pro gasket set won't fit inside the springs. Anybody know what kind I need to get that will fit?
I get valve float @ 5100 rpm with Crane 99835 springs on that exact cam. Just thought I would let you know. Since you're running that cam on a 318, I would think power would peak @ 5400 rpm. I'm thinking that Lunati knows what their doing. You could always give them a call too.
Keep in mind I'm running 2.02 intakes which are heavier and 1.6 ratio rockers.
I really would prefer to do it right, but I don't have the capability for it at this point. Come to think of it, I think it's fine that I might have to do that next year as I plan to port my heads in the future anyway. In stock form I don't know if these heads will make much power past 5500 RPM anyway. Hell, this is my first time even inside an engine, so there's probably a chance I'll blow it up when I go to start it anyway.
What's funny is that my dad doesn't golf or do any of that stuff. Come to think of it, my dad doesn't really have any "hobbies" of his own besides martial arts and working out/running (blech, who wants to do that???). He's a very "practical" man, and finds no point in spending money on anything besides the bare essentials; obviously, he doesn't think very highly of me dumping thousands of dollars into an old "muscle" car just so I can get it running well. My friends just don't get it either. I've come to the conclusion that you either "got it" or you don't; if someone can't imagine how spending four hours under the hood of an old truck trying to pry off a pair of 50-lb. cast iron cylinder heads from a dirty, greasy engine could possibly be fun, then they obviously could care less about how fast their car goes or even what car they drive.
EDIT: If the single springs w/dampers have the same specs as the dual springs w/dampers, what's the difference anyway?
and I am a 20 handicap for golf. Cars need to have thier place in ones life. I recently sold most of my stuff and all my cars for that reason. I plan to golf more this year.
Oh crap, I knew I'd offend someone with that, just not so quickly, lol! Fine then moper, sell all your cars, buy a nice set of clubs. I'll be in the shop. :-D Easy for me to say as cars are not my living anymore, makes it a lot more fun. It's how I decompress after work.
ram - I tink I grasp the harmomics, I just dont think it's that huge a deal with such a mild grind... I also don't believe you should have float... What height were those Cranes installed at? You notice I said he should run some shim to get the "lesser" spring into the range we need it. Also, did you test the spring pressures on them? I KNOW MP has some bad spring issues. They go weak in a very short time with the larger or aggressive ramp cams. I've never had trouble with Comp or Crane springs, but there's always a first time. I'd like to hear BJRs take on this thread too...
LOl... I should start by saying two things... I'm not THAT OLD!!!! and I am a 20 handicap for golf. Cars need to have thier place in ones life. I recently sold most of my stuff and all my cars for that reason. I plan to golf more this year.
You sure its valve float and not a fuel delivery problem? Just wondering how you know its valve float?
