Show us your home made tools
Shop, Garage and Tools
04-03-2009, 12:42 PM
#1
Tyr Fryr's Inc.
After another member posted a pic of a home made tool he made I thought to start a thread showing off our home made tools. You know the ones that are usually expensive and you only use once a year. I made a few so I'll start off with a few I made. They aren't necessarily pretty but do the job just fine.
First 2 pics is a clutch pack spring retainer compressor that I originally built when rebuilding a buddies turbo 400. It also works just fine on Torqueflites. Not pretty but works fine.
BTW: I use mine in my press but I'm sure you could drill a hole through it and use threaded rod through the middle with a plate on the bottom to pull it together if you don't have a press.
Second pic is a set of dial indicator extensions I made from 3/8" aluminum round rod. I just unscrew the tip off of the dial indicator and slip on what ever length I need. Allot cheaper than buying 3 different length dial indicators. Only trick was drilling straight into them but with a drill press it isn't hard.
Third pic is an adjustable pushrod length checker made from 2 old pushrods. I just wacked them in half close to the lifter and ran a thread tap on them and coupled them back together with a long nut I found at ACE hardware. You'll see it works on both ball/ball and ball/cup pushrods and adjusts from 7.2 to 7.8". Only problem is you have to have the intake off to do it cause they won't go through the pushrod opening in the head. Next one I do I think I'll tap the i.d. and use a #8 or #10 screw with lock nuts for the adjuster. I think that should clear the opening in the head.
Fourth pic is a roller lifter I took the guts out of and made it solid. I use it when degreeing in cams.
Last 3 pics are a valve spring compressor for changing springs with the engine assembled onto the engine. I mainly use it to install the inner springs after cam break-in. It's real easy to use. Just bolt it down to the rocker shaft bolt holes between the cylinder your going to do. Do one then slide it over and do the other cylinder.
So if you guys have some other neat tools you would like to share with us please do so. And don't forget the pictures. I think we can all benefit from saving a few bucks.
04-06-2009, 04:31 PM
#2
A-Body
Here's some I made.
First one is a Holley carburetor stand. Hey don't laugh, it works.
Second one is a spark plug air hose attachment tool. When heads are on engine, this holds valves closed for changing valve springs or seals.
Third one is an engine plate for pulling engines. This one I made but didn't weld. I don't trust my welding skills.
Fourth is a tool for turning the adjusters on an 8 3/4 rear. A fine example of my early welding ability. LOL
04-06-2009, 06:06 PM
#3
Mope or Nope
My down and dirty scrap metal torsion bar remover .
04-06-2009, 08:17 PM
#4
Tyr Fryr's Inc.
Thanks for the posts guys. Great ideas.
04-06-2009, 11:43 PM
#5
Crusty Old Geezer
Quote:
I like that pnuematic valve tool - gotta make one of those!
04-11-2009, 11:28 PM
#6
Remember Landy
got tired of renting a trans. jack so i came up with this
04-11-2009, 11:35 PM
#7
Tyr Fryr's Inc.
Looks good Camd. I always planned on making an attachment for my floor jack but never seemed to get around to it. Maybe one of these days.
04-12-2009, 12:11 AM
#8
Thread Inturpreter
heres an easy one for anyone to slap together,
great on the end of a breaker bar for those extra tough bolts, removing glass and windscreens, makes a great clamp in allmost any position, or even that little bit of extra thump to move something stubborn.
just remember you saw it here first
A brilliant multi purpose tool  apparently, theres a beefed up version with a steelcap boot attatched too!!
04-12-2009, 12:24 AM
#9
A-Body
Yup, that's a good way to break a toe! Ouch!
04-12-2009, 03:07 AM
#10
Senior Member
engineuitive is that how u spell it.
i make em all the time and am right up there w/ fishy but my spring changer is made out of an old rocker and shaft. will post later for sure i thought about doing this same thread good one fishy.
04-13-2009, 02:05 AM
#11
future prostock driver
cam--
i need to make one of these soon !! great idea ! are there any issues when you get the trans at an angle ?
04-13-2009, 09:49 AM
#12
A-Body
Quote:
Ha! Here's mine. I put this on the floor jack and it lets me rock the tranny around to line everything up. What can I say, it works for me. LOL
04-13-2009, 06:44 PM
#13
Remember Landy
496dart, right now I'm working on one that has an adjuster on it so you can angle it but im going to have to modify the pad on my jack so it can be secured solid. this one works fine for the lighter 904's since you can just pick up the tail to lock it in. i will post some close ups of the mechanism when I get it sorted out.
04-13-2009, 07:53 PM
#14
demon--that looks easy enough- hard to tell in the pic-what are the dimensions --roughly ?
04-13-2009, 08:28 PM
#15
Junior Member
04-13-2009, 09:09 PM
#16
Tyr Fryr's Inc.
Zack82192 welcome to the board and tell us about your home built tools.
04-13-2009, 09:29 PM
#17
Junior Member
thanks well the first one is a stop for when i was installing the wrist pins in my new pistons after the connecting rods where heated up
second is a crank shaft polisher i hooked up a low speed drill to the crank shaft polished away
04-13-2009, 09:54 PM
#18
Tyr Fryr's Inc.
I thought that's what they were but didn't want to appear silly if I was wrong. Thanks for the input.
04-13-2009, 11:11 PM
#19
A-Body
Quote:
Basically it's made with a piece of 5/8" plywood and firring strips. I just built a box around the jack pedestal. Then I glued some rubber on top for a cushion.
04-14-2009, 07:59 PM
#20
Senior Member
My portable bodywork / shop light... Made out of 4' fluorescent light attached to a patio umbrella pole mounted on wheels....
05-05-2009, 01:42 AM
#21
i made one tonight--out of 3/4 plywood, but mine lets the pan sit down inside the whole deal . The trans came out super easy--i am thinking this will be the 1st time i can put it back in by myself.
05-05-2009, 04:50 AM
#22
FABO Moderator
I,m thinking about making a couple adapt. for the floor jack..
1.For a 833,4 speed tranny(they,re frikkin heavy)
2.For center sections(easy install or swap)also frikkin heavy!
Great ideas guys!!
05-05-2009, 08:14 PM
#23
Senior Member
Quote:
I'm going to make 2 of these! So much for need to mount on my cement block walls! Thanks
05-05-2009, 08:18 PM
#24
Senior Member
That Is Some Great Stuff...
05-05-2009, 09:59 PM
#25
I know its a f ing b body
a motorcycle jack works great too. i couldnt do my 4x4 dually without it. i,d hate to drop that on me.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
