mr gasket vertical gate shifter
DUSTERDOWNS
DINWIDDIE VA
Can Anyone Help Me Locate A Complete Mr Gasket Vertical Gate Shifter For My 70 340 Duster. I Am Trying To Put Mine Back As It Was New In 1970. If It Is Vertical You Know You Can't Miss The Hole!
I don't think they came with V gates in 70.:-D Are you going for the day 2 look?
I have a complete Vertical Mr. gasket shifter for sale,make a reasonable offer!
do you still have the shifter for sale and do you have the rods as well
I REALIZE THAT DUSTERS DID NOT NOT COME WITH a v-gate SHIFTER I SHOULD HAVE SAID ( AS I PUT IN MINE WHEN I BOUGHT IT NEW IN 1971) I AM REBUILDING ONE IDENTICAL TO THE ONE I HAD BACK IN THE DAY, AND I INSTALLED A V-GATE IN THAT ONE AND REALLY LIKED IT. STEVE
Do you have to cut the stock 4 speed tunnel or hole to fit one of these?
I'd be interested in one,too. If one of you proud owners can PM me with what you'd like for it, I'd happily take it off your hands.........
Yes the hole is quite a bit larger than the original. Take a look at the size of the boot in the photo above and you can get an idea of how big it needs to be. On an A body the mounting bracket locates the shifter up higher and farther foward than stock. I just happen to be roughing out this install in my car right now.
