Sedanman
67-9 Valiant specialist
I Have A 67 Signet 2 Dr Sedan W/ Facory Buckets,was A Slant Now Is A 273,904 8 1/4.it's Been Swapped Over To The Big Bolt Pattern W/ Spool K Frame W/ Sway Bar,new Manual Disc Brakes,bbp Rallys W/ New Tires (not On Yet),new Fuel Tank & Sender,brake Lines,front Brakes,elec Ignition,newer Single Exhaust (needs Tail Pipe).i've Lost Interest In It & Found Something Else I Want.this Car Is Rust Free & Has A Blasted & Painted Trunk Area,wheel Wells,door Jambs, Undercarriage & Engine Bay In Alpine White.it's A Rainbow Of Colors Because I Searched For Years To Get Rustfree Body Parts.i've Had This Car In The Garage For 15+ Years & It Deserves A Better Life.i've Been Putting It Back Together So It Will Run & Drive Again & Am Almost Done.$3500 Obo
