And it begins....
thanson_mopar
Black Hills, South Dakota
UPDATE: NEW PICS
Well i started at going to school at HRI (hot rod institute). Love the school and what im learning, already learned how to MIG and TIG weld. This is the only pic i have as of right now, the rest are on my camera. the plan for right now is to do almost complete teardown. build subframe connectors, build 4 point roll cage, build a set of caltracs style traction bars fix the engine mounts. Get new bushings and rubber for the front end. Im taking the chassis fab class right now. Will be doing alot more with the car in metal fab and refinishing. Im also planning on a new interior, make my own door panels and all new upholstery. this pic is just at the end of the first day of teardown.
I am proud to see thanson mopar getting some training in and having fun.:cheers:
Do they except volunteers,=P~ That would be to cool :-D
I do widows and floors and trash :toothy10:
Thank you for sharing thanson, Make us proud :happy10:
thank you, the teardown is still going, got a little more done today, ill get interior out tommorow and take some more progress pictures. looks like alot of brackets and misc parts that im going to have to get powdercoated....looks like ill be contacting leana about some powdercoating.
New progress pics
trans and member out
lol, everything in this next pic except for the tires....:(
kid who was helpin me
......finally found cancer :(
the rest looked fairly solid though
Congrats to you! Keep up the good progress and keep the pictures coming!
Learn all you can while you are there.
Matt
Matt
thanks, im taking pictures of every step of progress and ill keep fabo updated every few days. ive learned a ton here and have only been here for just over a month, really impressed with the school
I envy you man. I would have given my left arm to have taken some training like that,,,,,,,,,good luck doing what you love.
got more done today, more progress pics tommorow, bad news for the rear glass though, accidentally broke it when taking it out. ruined the morning for me a little bit but got over it, coulda been worse.
Wow, lookin' good Tate:cheers:
If you need a backlite or a new floor pan, i've got both for ya.
Keep up the good work:thumblef:. You've given me som motivation to work on the wifes car
Finally started doing some real work. Bought 1.5 inch tubing for the roll cage and subrame connectors. Bent the hoop and the rear bars. not done with the subframe connectors or mounting pads yet, but the cage looks cool just sitting in there. Also just bought a 78 volare wagon for parts
It is looking really good. So...what are your plans for the car ? Are you going to keep it Yellow ?
thanks, the plans are resto/mod. The roll cage will be the only custom touch that is noticable. Will greatly stiffen up the car, the cage will be tied to the rear subframe and the subframe connectors. I will be repainting the car Citron Yellow, and I will do it right and paint the whole car inside and out like the factory did. you can see the origional color in these last pics....kind of a fawn tan color....not crazy about it.
Also got part of the passenger side subframe connectors done today. Will definitly post pics of those, they look cool.8)
here I got the spring perches moved and tack welded in.
Here is the driver side subframe connector I bent and welded up....pretty happy with the way it turned out.
New super stock leaf springs and U-bolts from Mancini Racing!
rear bars tacked in
poor picture, have the connector in for test fitting and tacking into place
connectors tacked into place :love7:
lookin good!
Thats so cool a school...just provide the car and parts they provide the technical help and know how!
Will they help you look for a job too?
Aloha!
