Post your sound bytes here.
Mopar Exhaust
04-04-2006, 01:38 PM
#21
Senior Member
that putfile gets screwed up alot.. try zippyvideos.com
04-04-2006, 03:45 PM
#22
Senior Member
So I'll put this in the PROPER thread.
Engine is a 408 stroked 360
W2 econo heads-home ported.
11.5:1.
MP M1 intake with 750Demon.
Hussler headers and 3" exhaust.
Let's hear more.
04-14-2006, 09:18 PM
#24
FABO Moderator
heres my pig!!!!
340
10:1
XE294H .519/.524
SUPER COMPS 1 3/4"
3" EXHAUST WITH SUMMIT RACING MUFFS before the rear.
04-14-2006, 10:26 PM
#25
Registered User #1824
these things get better all the time......more!
04-15-2006, 12:33 PM
#26
Member
318
I believe it is stock cam (I recently aquired the car and havent got much done)
Unknown Headers (I believe DynoMax)
Dynomax muffers (Dual with no X-pip)
This was before the re-tune of the engine, i will try to get a newer clip also.
Depending on how many people are opening the file, you may have to let it buffer then restart the clip..
Intense-Dakota's 1970 Dodge Dart Audio Clip
PS> This was in the winter (thats not oil burning, it was really cold)
04-15-2006, 06:44 PM
#27
Senior Member
Ooooh! This is why I like small blocks.
06-10-2006, 07:48 AM
#28
Senior Member
528 Hemi Duster, Dr. Gas X-pipe, Flowmasters
Here's HemiMark's orange 528" HEMI powered '71 Duster starting up
to drive over to the Nat's about 30 miles away.
Quarters say 340......air cleaner says 426......but..............
Hooker super-comps (modified for street use), Dr. Gas X-pipe and
two-chamber Flowmasters with full tail pipes.
http://s3.photobucket.com/albums/y93...OMMAMOVIE2.flv
07-08-2006, 10:28 PM
#29
A little misguided...
Here's a new sound clip for my car:
Click here
360, 455/475 Herbert cam, ceramic coated headers with 1 5/8 primarys and 3" collectors, Edelbrock RPM stainless mufflers.
07-08-2006, 11:23 PM
#30
Member
nice, i am installing new Hedman headers, Jegs X-Pipe and Dual Flowmaster 40's (non-delta) this week, i will post my new clips as soon as I get the project done.
08-17-2006, 04:34 AM
#31
Senior Member
Engine size 318
Cam size 280H .480 int .480 exh 280dur. comp cams
Header brand and size 1 3/4 " tti stepped headers
Pipe diameter 3" exhaust to axle w/ drop offs
Cross over - X pipe, H pipe, none H- pipe
Muffler type and size 3" flowmasters 30 series
Tail pipes, size. none
sorry but I don't have any on idle quality but I will post them soon.
I can't listen to any from the put file site because I am limited to what I can do at work.
10-09-2006, 09:29 PM
#32
Senior Member
Hope this works
440 472 ci 512 hp 625 tqe
A833 4spd
Stainless headers
Just bought it --Don't really know the rest.
Sounds and runs great however, so that; all I care about
10-10-2006, 11:30 AM
#33
Mr. Goody
318, tweaked a little.
 open 3" cutouts.
lol
10-29-2006, 01:10 PM
#34
[quote=AdamR]Please post your exhaust sound bytes in this thread.
List the following info.
Engine size, 318 stock bore {1973 engine} stock compression ? 8.6:1?
Cam size Mopar Performance # 4452759
Duration at 050 inch Lift: 221 int./228 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.430 int./0.450 exh. lift
Header brand and size Stock 273 exh. manifolds
Pipe diameter start at 1 7/8" necked up to 2 1/4"
Cross over - none
Muffler type and size Dynomax Super Turbo 2 1/4"
Tail pipes, size 2 1/4" then thru 340 Dart chrome tips.
# 302 casting heads
LD4B intake 1968 era?
# 1406 Edelbrock carb. stock jetting, used out of the box, except for linkage
http://media.putfile.com/1964-Valiant-dual-exhaust
hope this works, LOL.
11-03-2006, 11:26 PM
#35
Senior Member
New One..Old one vanished!!
Did this once before, but was deleted.
Little motor, Little driveway burn!  NOT LIKE MOST.
ENGINE: 273
CAM: 252/.425 Basic Stock
HEADERS: Flowmaster
CROSSOVER: H
MUFFLERS: Cherri Bombs (Glass Packs)
PIPES: 2.5
http://media.putfile.com/Spin-42-52
11-07-2006, 08:50 PM
#36
It seems Putfile is kaput, LOL.
Try youtube.
1964 Valiant dual exhaust
[quote=cavemanmoron]
Cross over - none
# 302 casting heads
06-11-2007, 02:53 AM
#38
OK, a new, up to date clip of my exhaust.
Long tubes 1-5/8 primaries, 3" collectors.
2.5" pipes with crossover
Edelbrock 2.5" SI/SO RPM stainless mufflers
Motor is a basic 9:1, 4 barrel, with ported iron heads and 455/475 cam. Idle here is about 1000 rpms. No stall converter yet, so she has to idle high to keep from dying in gear.
06-11-2007, 06:39 PM
#39
7172 duster
414 Stroker, INDY cyl. heads,crane flat tappet cam 587 lift , 250 @ 50 duration , 11.5 compression , Hedman hustler headers thru 3.5 dynomax bullets , 850 quick fuel carb [IMG]  [/IMG][IMG]  [/IMG][IMG]  [/IMG]
07-04-2007, 03:20 PM
#40
Senior Member
Here's the new bite........
Engine size: 408
Heads: W5
Compression: 12.5
Cam size: Crane Roller... .670" lift, 260/266@ .050"
Header brand and size: Hedman Hussler, 1&7/8"
Pipe diameter" 3"
Cross over - H pipe,
Muffler type and size: Flowmaster "knock offs", made just next door.........
Tail pipes, size. 3"
http://www.cherrey.com/viewtopic.php?t=277
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
| For the Mopar Owner |
Search eBay For The Part You Need
