A tale of two Dusters
bjkadron
Knoxville, TN
This thread is devoted to the build-up of my two 1972 Plymouth Dusters.
Hello everybody! My name is Benjamin and I am currently 18 years old and going to school for my mechanical engineering degree. Here are my two Mopar projects.
#1 My first Duster is one that I pulled out of a junk-yard that I am turning into a stripped down road racing street legal monster! I first found it when I was 15 years old. I couldn't actually buy it until a little after my 16th Birthday. Right after I bought it.. Our main vehicle Died and I couldn't get together with the guy to get it home until just after my 17th birthday. It is going to have a NASCAR/ Vintage TA theme. My eventual goal is to build it to be the fastest street legal road racing Duster ever(think Big Red but a Duster)! And The Name I've come up with is the "Aero Duster" to recall the "aero cars" of NASCAR.
The body is getting fully stitch welded to increase rigidity along with my custom designed "backbone" subframe connectors and probably a 10+ point roll cage.Although I'm thinking about going all out and building a full tube frame for it. I'm also going to shave things like the gas cap, antenna and front bumper (that mess up the lines). Its going to get a front splitter type spoiler and NASCAR type rear spoiler and a possibly Hemi Dart scoop. A primer gray and flat black "paint" job will make it pretty. I'm putting it on a Major diet with a lot of lightweight parts. All new fenders, hood, trunklid, probably doors will all be custom made by Me out of either carbon fiber, fiberglass or aluminum(I'm still deciding) as well as a full Bellypan and rear diffuser. I'll have lightweight glass(except for the front windshield which has to be DOT glass for it to be street legal)and I'm mini-tubbing it in case you haven't figured that out. If I decide to go the full tube route I have decided to make it a “modular” design so I can just swap out body panels and wheels/tires to totally change the configuration to be better suited to whatever I happen to be doing at the time(road racing, autocross, open road racing…)
The interior could be described as "sparse" with just two(maybe 4)racing buckets, aluminum panels and zolotone along with a pistol grip(custom) shifter and a custom steering column.
Suspension will be, front: adjustable upper control arms with torsion bar lowers(all new high performance bushings) in the front or a custom clean sheet double a-arm fully adjustable suspension and k-member(depending what class I decide to run in) Steering will be stock box with a quickener that will make it 13:1 and aerospace aluminum tie-rods and drag-link(or maybe rack and pinion to loose some weight). Rear: custom adj. 3-link with panhard rod. Adjustable shocks all around. Also I'm fabricating some adjustable front and rear sway bars.I have been thinking about a torsion bar(non-stock)front and rear suspension (think indy-car)instead of coilovers so I can adjust the ride height and spring rates as well.
Brakes: Big discs with 6-piston front and 4-piston rear. and a separate "rally brake" for drifting and such.
Wheels and tires will be genuine NASCAR AERO wheels with "Big"(315's front and 345's rear or thereabouts). And forged aluminum w/ road racing slicks for the track.other wheel options are, a torque thrust type wheel(think Foose Nitrous or VWW v40's or the like),or maybe something like Big Red's BBS wheels(all in black).
Drivetrain: I've been looking at sequential transmissions.. But they are EXPENSIVE!!! So I'm not sure.
Engine: either a stock 360sb with ported heads and an Eaton supercharger that I found or a new HEMI(with the same). But eventually I'm going to put an all aluminum sprint car engine or a used NASCAR engine in it.
I'll have a big aluminum radiator, and a fuel cell with all new fuel lines.
Jegs headers(Custom on the new engine) with a custom x- or H- pipe and side exit exhaust to spit the fumes (I haven't decided what mufflers).
I'll be finishing it to show car standards(I'm a bit of a perfectionist) and I would be glad to accept sponsors if someone likes my Ideas!And would be able to get it done faster if I had some! In case I mislead you by saying that its going to be "show quality"... Its not going to be shiny! I don't do shiny(at least not on this one).
Probably the coolest thing that has happened with this project recently is My car being featured on page 67 of the August 2009 issue of Popular Hot Rodding Magazine! Unfortunately they spelled my name wrong… its Kadron not Kardon.
#2 As you can see the plans for my duster were quickly spiraling out of hand.. And since I wanted to drive a duster soon.. I did what any mopar nut would do! I bought another nice clean, stock '72 Duster to drive in the meantime! Its a nicely optioned gold Duster with a 318 and an automatic transmission with 73,577.5 original miles. It has A/C, PS, AM/FM radio, and a bone white interior. I havn't decided exactly what I'm going to do with this one yet but I'm sure I'll think of something. Currently on the list are: disc brakes, better wheels/tires and some nice shocks.
Sorry about the lack of pics guys.. I've uploaded a bunch to photobucket and will post them here soon!!
Thanks for looking and have a wonderful day!
Benjamin
While my plans for my Race Duster sound cool I have to change plans. I was adding up costs and found that if I wanted to get it done within the foreseeable future I was going to have to do something different. So I did. I am now building the car for the "group 1 A sedan" class in the vara. That means that I am pretty much limited to stock parts and lightening it.. Though they do have some "wiggle room" that will allow me to gain a performance advantage. I will be building up a '70 318 that I have for the engine. Swapping in a 833, and converting the fronts to disc brakes. So my biggest expenses now will be springs and shocks and adjustable rockers (they have to be period). More on this tomorrow! Thanks for looking!
So... I got my Addco Swaybar (used from Demonduster) and am waiting to install it until after I do the disc swap.
I have no clue how it drives yet. As I am still waiting on a trunk pan so I can install the gas tank. I am getting one from another member here but I have not received it yet. I did however, have a taste of what is to come when I was moving it (hose stuck into a bottle of gas) and I got the feeling that I am going to enjoy this small block(318) in a light car. I had driven smog engined vans and trucks before but noting as light as a Duster. So Suffice it to say that I am eagerly awaiting the time when I can hammer the throttle in my new baby!
Also I got a 833 with a Hurst shifter for my race Duster. So all I need now to have a complete driveline for it is a clutch and a stronger rear end. Everything is coming together nicely!
That is about all for now. Hopefully I'll have another update and some more pictures soon as I have a few things I'm working on.
Thanks again for looking!
Benjamin
(bjkadron)
My newest Duster
Side view
rear 3/4
trunk (the stuff came with it)
.........there's the pics
Any chance we can see these custom designed frame connectors? Sorry if I missed the link but theres a lot of them...
Nope sorry... They are custom designed, Not custom fabricated yet. :) I designed them to work like a backbone style frame and greatly increase the torsional rigidity. Not for the faint of heart though. I'm going to have to remove most of the center tunnel and make a new one. I'll sketch one up soon and post a pic for you cause I'm not quite ready to make them yet.
As for the links... I don't know why they posted them that way... They were supposed to be pictures... I don't know why it didn't work.
There are several link options with the pics at photobucket. Maybe you used the wrong one? I've done it...
use IMG rather than URL...
Update!!! I FINALLY got the trunk pan in and the gas tank hooked up so I can drive it around. It drives really nice! I was also really surprised how well it handled as I have heard a lot about how bad they take corners. I'll admit that it feels shockingly similar to driving a boat... But it is a v8 powered boat so I like it! Driving it has also showed me what areas need attention and the list so far looks like this(in no particular order):
Get the dash lights working
Fix the fuel gauge
Get better headlights
Fix or get a temp gauge
Install a Tach
Seatbelts!!
bleed the brakes
And that is about all I can think of right now... I'll let you know how everything goes.
Thanks for looking!
Benjamin
I forgot to take a before picture but here is the piece that fell out.
Cut and prepped.
Other pan.
After I cut to fit.
Weld it in!!! (yes.. I know I don't have gloves on..)
Finished product
Playing around with some hood scoops..
