riegerplumb
Active Member
Impulse buy for sale.Went to Chryslers at Carlisle looking to purchase a 73 or 74 dart sport..came home with this.I see it was on this site for sale a little while ago by the fellow who built it..Details are,,no rust body ever.Pa antique title/tag in my name.Mileage shows 103,000.Original body and paint.Someone did try to do some engine bay touch up in the past.Does have a few small dings and scratches here and there.Interior shows well for age including headliner.Manual steering and brakes.Lights,signals,wipers,heat,defrost work as they should.Front seat belts.3000.00$ spent on tub work(have receipts).Spring relocation kit with new leaf springs and bushings.Kyb gas shocks,narrowed 8 3/4 out of a 66 charger,Moser axles,489 case with 3.23 gear(open).Disc brake conversion on front with drilled rotors,tubular upper arms,new ball joints,lines and hoses.15x8 rear rims with 50 series tires,front are 15x4.5 with 80 series.This is a 6 cylinder gt converted to an 8.A 64 four door 273 car was used for a donor.Car came with a stack of receipts.From what I can tell engine received a new solid cam and lifters,oil pump,milled heads,timing chain,water pump,fuel pump,carb,electronic ignition.Push button 904 shifts up and down nice.Stock converter,stainless trans lines.All new driveshaft and U joints.Gas tank and sender replaced.Good sounding dual exhaust nicely done.We drove it home on turnpike from event..75 miles.Had to a few local cruise nights..everybody thinks its cool.Only things I have done are a heater core change,Brad Penn oil change,dash cover.Did come with new seat foam kit..one was done already..have the rest.Car cover included.Good foundation for a healthy 340 or 360 upgrade..............I will try to respond to questions or comments within 24 hours.13,500$ any serious interest feel free to contact me.I am 15 minutes from Maple grove raceway ....thanks Rob
