ChristinesFury
Member
Hi forum members, first time joining one of these so thanks for any help in advance.
Although not an A body, had the 727 out of my 1965 bb 383 fury rebuilt as it was leaking and barely sliding into 3rd. After having a friend of friend rebuild it, it wouldn't shift into 3rd all the time unless you rev it hard in 2cd then it will shift sometimes.
He stated the valve body was cracked so he jb welded it before he put it together. It shifts into reverse and drive fine, pulls good through 2cd but won't shift into 3rd all the time. Adjusted kd linkage to no avail. shortening makes it slip so adjusted almost although the way out flush. After extensive research only thing i could find was either the valve body or governor. He stated governor was fine.
Luckily my brother had same transmission out of his fury with same pristine valve body. he put it in, still wouldn't shift. pulled it apart as i noticed online possible causes could be governor plugs. bought sonnax governor plugs but they were different (newer 727 presumably) so we had the stems milled to fit. also sonnax oversized servo and accumulator kit as well as transgo shift kit which just included the new manual valve.
while installing the new parts he now notices another hairline crack in the same area as the original value body. So i told him i know how to fix properly with jb so i know it's fixed correctly. application went perfect. he put it all back together, test drove and just informed it's exhibiting nearly the exact same symptoms??? What else could he possibly have done wrong, or have gone wrong? Although i've worked on cars all my life, not a trans guy but after all the research i think i could almost rebuild one myself. but im smart enough to know there's no replacement for experience. Also installed a deep pan and filter extension.
Any help would be much appreciated.
Bob.
Bob.
