1965 Barracuda Radiator?
Discussion in 'Heating / Cooling / AC' started by Bruce Leee, Oct 22, 2017.
  1. Bruce Leee
    Bruce Leee Well-Known Member
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    So my core is leaking and needs to be recored $450? This is the original to the car. I like the look of it. Are there any replacements that have the same look? If not then what would you do? Recore it or put a new Aluminum one in? Thoughts and ideas?
  2. circlepilot
    circlepilot FABO Gold Member FABO Gold Member
    219
    98
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    8:47 AM
    I went with an aluminum radiator on my 65/ until I get the original one re-cored. I haven't priced the re-core yet, but $450 sounds kind of high.
  3. circlepilot
    219
    98
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    8:47 AM
  4. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    That looks nice. 3 core? What model / brand is it? Off topic... what color is your car painted?
  5. circlepilot
    219
    98
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    8:47 AM
    Yes three core...Champion Radiator. The car's color is original (at the moment) metallic blue. The radiator I bought, is for a 65 Dart, passenger side lower hose. I had to add an extra piece to the passenger side flange mount to install it in my 65/. It worked out great. Champion may now have one for a 65 Barracuda 225/, but at time I bought this one they didn't. Currently I have the car disassembled for restoration. It had been sitting in a woman's yard since 1988. I drove it around for a couple of months before I started on the restoration.
  6. RichB
    RichB CherryCuda65
    75
    23
    Feb 10, 2016
    South Carolina
    Local Time:
    9:47 AM
    That radiator does look good. A radiator shop should be able to find the leaks and fix them, clean out the radiator and pressure test it. I think an aluminum radiator would look way out of place. Keep it original.
  7. circlepilot
    219
    98
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    8:47 AM
    You are right. Like I said...when my original is re-cored, Ill reinstall it.
  8. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    Yes I want to keep it as original as possible. That radiator just does not look right.
  9. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    8,243
    805
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:47 AM
    I had 3 65’s that I was planning on doing so I sourced 3 22 in radiators and had them recorded to a 3 core (not all at one time of course). 2 of them were for V8’s 1 for a slant. I’m now down to 1 early A and am keeping the slant radiator for it; I will keep one of the V8 radiators and try to fit it to my 47 making one of the V8 radiators available. Interested?
  10. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    Got a photo?
  11. 65 Dartman
    8,243
    805
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:47 AM
    Yes I can get pics - do you have an auto or stick - makes a different in the bottom tank.
  12. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    I have an auto.
  13. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
  14. 65 Dartman
    8,243
    805
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:47 AM
    Here’s some pics I just now took of the radiator.
    22 inch core - correct for an early A V8 2D4D5845-F9C4-4A37-AED4-E98A5A80CBDE.jpeg
    Overall shot of the radiator - does have the correct rounded top tank with the upper/lower hose fittings in the correct locations for a V8. The radiator guy put the side panels that were on the radiator back on - they are not correct for a 65/66 as they do not have the correct mounting area to install a factory shroud F4B7EF12-A328-4D76-B689-736CDE07A844.jpeg
    Cooler fittings in the lower tank
    3 core!
    None of the 3 radiators I had done have ever had coolant run through them nor painted - pretty much as received.
  15. halfafish
    halfafish 66 Valiant, hot-rod in training FABO Gold Member
    151
    64
    Aug 14, 2016
    SW Washington
    Local Time:
    6:47 AM
    My radiator was leaking when I bought the car, so I replaced it with a 3-core Champion aluminum model. It works great, but with time I decided to recore the original. If you're only paying $450 you are better off than I am, mine was $550. But I really like the look of the original, and it will fit with my goal to make the car a sleeper.
  16. 65 Dartman
    8,243
    805
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:47 AM
  17. circlepilot
    219
    98
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    8:47 AM
    I agree Dartman, A slant radiator has a passenger side lower hose nipple and an offset to the passenger side, upper hose nipple...BTW the lower nipple is angled toward the passenger side for hose clearance.
    Norm
  18. Bruce Leee
    72
    28
    Sep 9, 2017
    Texas
    Local Time:
    8:47 AM
    I have a slant 6. I want a correct looking radiator for this car.
  19. 65 Dartman
    8,243
    805
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:47 AM
    A correct appearing radiator for your year with a slant is a 19 inch core with the wider passenger side mounting bracket. Your best bet would be to get your's re-cored.
