1966 & older clutch & brake questions
coalman
Texas
1. Are all clutch & brake assemblies under the dash the same for six's and V-eights, and the assemblies in front of the fire wall for six's and V eights are different?? Thanks
Pedal assemblies are the same. The under hood difference between them is the Z bar. The brake master cylinder is the same.
Gas pedal assemblies are different between slant and V8 unless the slant has factory AC. Then the pedal assembly is the same as V8s.
Firewalls are the same for slant and V8 when they are equipped heater only; firewalls are the same for factory AC-quipped AC V8s and slants.
