moparraceman
have for sale late 1968 block guess actually used in 1969 cars dart 340 275 hp std bore been cleaned at machine shop , and checked , i painted it ,stock steel crank std,std as is the block std bore have the stock 10.5 .1 pistons . have a comp double roller timing chain and gears ,front cover,windage tray , water pump,fuel pump ,i have new freeze plug kit,new cam bearings,rod and main bearings,and new rings ALSO STOCK RECONDITION RODS WITH NEW ARP BOLTS NO OIL PAN OR OIL PUMP do have a dist drive gear nice shape .$1750 nice pc pick up ohio thanks
