Some pictures of my 70 Swinger 383 project. More pictures to come as it progresses.
383 40 over custom ground Cam to 509 specs 10.25 to 1 compression. Headers 383 torker 2 intake Edlebrock 750 carb.
Used the shumacker engine mounts. They worked great. Good instructions after setting it in had engine bolted up in 15 to 20 minutes. Definitely recommend them if doing this conversion. Used b body headers instead of the shumaker tri ys. Would recommend useing them. I followed the instruction per bigblockdart.com on installing them work but very tight fit. Ordered the shumaker tork strap. Only 1/2 to 1/4 inch clearance between the shock tower and header on passenger side. But over all a nice fit.
