RustyDusty
Rabid Cross-eyed Opossum!
1989 Ford F-350, dual rear wheel. 460 Gasoline motor. White, fresh paint this summer. Not a great paint job, but looks nice from 10'. Brand new Firestone Transforce tires (cost $1,500) comes with lifetime free balance and rotate. 87,*** original miles. Milage has not rolled over. Has a crack in the left rear fender. Great work truck, has been my daily driver while I rebuilt my credit to purchase a new truck.
The Bad-
Burns Oil, no smoke visible, but does burn oil.
Passenger side window regulator nylon gear is stripped. Window is stuck up.
Within the last 2,000 miles it has received
6 Firestone Transforce HT tires
Passenger rear fiberglass fender
All new brake hoses
90% of steel brake lines replaced. Remaining original lines are in very good condition.
paint
Cap
Rotor
Plugs
Spark Plug Wires
Sway Bar Bushings
Differential flush
Power steering flush
ATF flush and filter
Asking $2,000 for FABO members only.
The Bad-
All new brake hoses
paint
Cap
Rotor
Plugs
Spark Plug Wires
Sway Bar Bushings
Differential flush
![5Ld5T15J73L23I83J4c8199a93a5fe9fb1fd1.jpg](https://post.craigslist.org/imagepreview/m/5Ld5T15J73L23I83J4c8199a93a5fe9fb1fd1.jpg)
