Hi. Just joined this site and love all the mopar posts. Having a problem with my rebuilt 360 and wondering if anyone has experianced this or has an idea whats happening. Block was hot tanked,new cam bearings,plugs,bronze bushing. Crank was polished and mic'ed at machine shop. New bearings installed with 002" rod and main clearance. M.P/ Melling hv oil pump, hardened tip shaft, 7qt pan. Everything was checked and triple checked,cleaned and recleaned as i always do. 450" hyd cam and lifters were new. Indys rebuilt Aerohead 360 heads with 2.02 valves for future cam upgrade. Engine started right up and ran great for 4000 miles. Changed oil after first 100 miles, then again at 500 and 1500. Running Valvoline 10w40 with Lucas zinc additive and mopar filter. Oil pressure is cold idle50psi. Hot idle is 30psi and goes right up to 65psi over 1500 rpm. Problem just started coming home from work. Hit the throttle, and oil pessure drops quick. Goes down the road and idles fine, and i can rev to 5500 in neutral and all is well. Put it in gear and it doesnt matter if i go wot or half throttle, the pressure drops and i let off pedal, returns to 65psi. Anyone have an experiance like this just happen all of a sudden? Getting worried as its my work vehicle at the moment. Seems fine under normalish, light driving conditions, but i like hearing those turbo mufflers and headers sing. I tried a different gauge for the heck of it, no change. Thanks for any info or input.
