[SOLD] 373ci. Stroked 340 engine
hotrod426
michigan
This engine was built for me buy Tico racing in Somerset Center Mi.(now retired and no longer in business) several years ago with the intent of putting it in a duster. I realized awhile back that I am not going to use this motor, you know plans and ideas change. So here's what l'm selling 373 ci stroked 340 small block that produces 417 hp ag 5410 rpm and 412 ft-lbs of torque at 5018 rpm. It is a 340 block with a 1-9-69 casting date, stamp on pass. oilpan rail (this is not a real good stamping) 0P128346, stamp under drivers cyl. head (again not a good stamping) FW40p2980135.
Here's whats inside:
-The block was cleaned , magnafluxed, sonic tested and deburred, align honed mains light resurfacing the deck, and overbore of ,035".
-ARP main studs, rod and main bolts
-360 cast crankshaft magnafluxed and inspected,mains cut to 340 size and full radius added and then surface hardened.
-Clevite 77 Tri-metal bearings
-Diamond high-swirl dished pistons 9.5 to 1 comp. ratio
-stock 340 oil pan
-melling high volume oil pump
-radius polished rear main cap oil port to aid flow to crank
- Milodon windage tray
-Comp Cams solid lift camshaft 230/236 at .050 inch, valve lift of .521/.536
-Comp Cams moly pushrods retainers, locks and valve springs
-Crane/Wolverine 1.6 ratio presision bearing rocker arms
-magnum heads which have high swirl 62cc combustion chambers
-intake valves with .450 longer stem w/2" dia. valve
-exhaust valves 1.62" dia.
-heads are pocket ported and a little massaging of the intake and exhaust port runners
-Mopar M1intake manifold, edelbrock water pump , March crank and water pump pulleys
Also included are MSD super-conductor 8.5 mm wires and a MSD billet E-curve distributor. This was built to be a fun streetable motor, I have close to $5500 invested and I am asking $4700 because it is an older build. I think that I have everything listed but feel free to ask any questions.
View attachment 1715083911 View attachment 1715083907 View attachment 1715083904 This engine was built for me buy Tico racing in Somerset Center Mi.(now retired and no longer in business) several years ago with the intent of putting it in a duster. I realized awhile back that I am not going to use this motor, you know plans and ideas change. So here's what l'm selling 373 ci stroked 340 small block that produces 417 hp ag 5410 rpm and 412 ft-lbs of torque at 5018 rpm. It is a 340 block with a 1-9-69 casting date, stamp on pass. oilpan rail (this is not a real good stamping) 0P128346, stamp under drivers cyl. head (again not a good stamping) FW40p2980135.
-stock 340 oil pan
Those are Magnum heads? You didn't say anything about the heads.
I was wondering what water pump is installed?
^^^^ Thanks^^^^
Good luck with the sale! I am sure it will make someone real happy
View attachment 1715085538 View attachment 1715085537 View attachment 1715083911 View attachment 1715083907 View attachment 1715083904 This engine was built for me buy Tico racing in Somerset Center Mi.(now retired and no longer in business) several years ago with the intent of putting it in a duster. I realized awhile back that I am not going to use this motor, you know plans and ideas change. So here's what l'm selling 373 ci stroked 340 small block that produces 417 hp ag 5410 rpm and 412 ft-lbs of torque at 5018 rpm. It is a 340 block with a 1-9-69 casting date, stamp on pass. oilpan rail (this is not a real good stamping) 0P128346, stamp under drivers cyl. head (again not a good stamping) FW40p2980135.
-stock 340 oil pan
where are you located hotrod426? I see it was built in Mi. and I'm in Mi. too so in hoping you may be close!!! thanks....
I'm on the north end of grand rapids about 2 1/2 hours from detroit area depending what area your coming from
