489 pinion shims are still available for mopar
couper 340
maryland
Just to let the people that don't know , Do to all the part # changes over the last 35 years
these pinion shims are still being used on dodge 9 1/4 rears new part# are 3432330 is .030th
just add the size to the end of the part # 3432335 would be .035th you can get from '020 to .038 very cheep from $2.45 to 8.60 .025 is is like $23.00 don't ask me why . also the large pinion nut is all so fits the 8 3/4 taper 29 spline pinion . 1500 ram or 2005 Dakota with 9 1/4 if you want to do it by model
you can also get pinion shims , bearings , pinion nuts etc. for all the cases 741,742 and 489 from Ratech Manufacturing --you can order direct or thru Summit
