I'm looking for pictures of aftermarket 6 pack set ups. I'm at the point where I need to put together my fuel lines. Specifically from the mechanical pump to the carbs. I working with a low deck 400. Thanks.
No. 6AN line from the fuel pump. Probably looking to build some sort of 6pack fuel logYou would want to copy that with a metal line routed however you please or as stock from the fuel pump.
Is this for a resto look?
That was pretty cool. I clicked the link and it automatically wrote what the search topic was inside of it.
Yes they do. I ordered it and will use it to create a set up using 6AN. Thanks for all your responseJegs sells the lines cheaper.
Exactly what I'm looking to do. Thanks!!!
That’s what I did. As if Yet the are untried.
