Hilderbrand1983
Working with a 1967 Dart 270. Since I bought the car in June, I assumed that the four-way hazard lights didn't function. This morning, I found out that they do ... kind of. Here's what I found out. If I put my key in the ignition and turn to the left, the hazard lights will function*. If I turn the key to ON or START, or if the car has been started, they won't work.
(*More or less. The rear lights and the passenger indicator light flash, but the driver's side indicator light doesn't flash. It works as a normal turn signal, but doesn't flash as a hazard light.)
Thoughts?
Thoughts?
