[FOR SALE] 7 1/4" Rear Axle
Discussion in 'Mopar Brakes, Steering, Suspension, Tires & Wheels For Sale' started by 6-david-5, Dec 6, 2017.
Thread Status:
  1. 6-david-5
    6-david-5 Mopars under construction
    101
    8
    Oct 9, 2013
    Magic Mountaindale
    View My Photos
    Local Time:
    12:39 AM
    Contact Seller
    Up for sale is a 7 1/4" axle out of my 1968 Dart. This rear worked well, and was pulled out of the car last month. It was pulled because it was replaced by an 8 3/4" rear axle. The car got a big block swapped in and the Slant-6 was removed at the same time. This axle was never operated behind anything other than the original Slant-6 & 904 TF.
    Please see my Craigslist ad for photos:
    https://losangeles.craigslist.org/sfv/pts/d/mopar-dodge-dartrear-end-axle/6415490713.html
    The brake lines were removed because we needed them for the other axle. The wheel cylinders are between 1 & 2 years old, and should have plenty of life left.
    It ran quiet and had clean 90W in the diff. I don't know the gear ratio, but I would guess it is around 2.76 to 2.94. Open differential. 5 on 4" bolt pattern. 9" drums. Comes with the brake drums that were used with it.
    Located in Santa Clarita CA. $50
Thread Status:
