AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,909
- Reaction score
- 12,263
Parked since 93!, Gee that's a sad story.
Glad to follow your revival.
Yea, after careful inspection of the bottom end this weekend, I have no fears that it will run. I hate those F...ng clamps too. All of them are going in the trash.Looking at the engine ,looks like a runner. Still has the beloved wire hose clamps. Never cared for those.
After sitting for 24 years there was no hard sludge in the bottom of the pan. We were amazed. Lemon Jr. really enjoyed cleaning up the pan. The crap was about a 1/4" thick on the outside. Character building experience. . We got the bottom end all buttoned up today. On to the cooling system next.
Stripped the canister today but definitely will keep it on the shelf. Clutters up the the engine compartment IMHO. We'll keep the vent line and fabricate a nice, small filtered solution for it.Nice. My first Mopar was a 72 Duster. Hang on to that charcoal canister - one year only, 4 connector, the restoration guys might want it if you don't keep it.
Kern Dog ,nice to see you. That is so accurate. Why even I slather roller cams in that dark grey/ black Stalube molybdenum lube.The reason that the top end did not get oil is because there are 2 passages that feed the rocker arms. These engines do not feed oil through the pushrods like GM engines, they oil through small passages in the cam journal. The cam has to be at a specific position for oil to shoot in, then it is forced through a passage in the block and head for each side. TO get oil to the top, the engine has to be slowly rotated while being primed. Once the "timed" passages line up, a copious amount of oil is forced through almost as a pulse. This was engineered to deliver the proper amount of oil to the top end based on demand. The crank gets the majority of the oil as it should. The cam lobes are merely splash lubricated from oil being thrown off of the spinning crank.
Are the rocker shafts , mounted properly? I do Magnums now... (I don't remember..) ,there is a notch in the factory hydraulic rocker shafts that must be followed.The reason that the top end did not get oil is because there are 2 passages that feed the rocker arms. These engines do not feed oil through the pushrods like GM engines, they oil through small passages in the cam journal. The cam has to be at a specific position for oil to shoot in, then it is forced through a passage in the block and head for each side. TO get oil to the top, the engine has to be slowly rotated while being primed. Once the "timed" passages line up, a copious amount of oil is forced through almost as a pulse. This was engineered to deliver the proper amount of oil to the top end based on demand. The crank gets the majority of the oil as it should. The cam lobes are merely splash lubricated from oil being thrown off of the spinning crank.
Hey Kern, good to see you here from FBBO. Runner 68 here.The reason that the top end did not get oil is because there are 2 passages that feed the rocker arms. These engines do not feed oil through the pushrods like GM engines, they oil through small passages in the cam journal. The cam has to be at a specific position for oil to shoot in, then it is forced through a passage in the block and head for each side. TO get oil to the top, the engine has to be slowly rotated while being primed. Once the "timed" passages line up, a copious amount of oil is forced through almost as a pulse. This was engineered to deliver the proper amount of oil to the top end based on demand. The crank gets the majority of the oil as it should. The cam lobes are merely splash lubricated from oil being thrown off of the spinning crank.
Oh, I see, but if you followed the whole thread you'll see around post 29 this issue was overcome by doing exactly what you state. Perplexed by my Pertronix question at this point. Any thoughts?Didn't I read the following correctly...?
"We pulled the distributor and tried to prime the oil pump with a drill, got a little pressure but it never made it up to the valve train. Rolled it over a little by hand to get the journals opened up and tried to prime again....nothing to the top.
It rolled over very smooth from the start, nothing stuck at all, which surprised us but good news none the less. I am however curious why I didn't get pressure to the top end.
My thoughts are 1. The Marvel is too thin to pressurize up top. 2. The pickup tube is gunked up and can't pick up."
This pertains to what I wrote about the "timed" oil passages that direct the oil to the top end.
It sure does 4spd, I'll just tie all three into one spade on the blue side. That's what I sort of figured but thanks for the confirmation.I had one hooked up on a C-body. The red wire ran to the blue wires on the ballast resistor, and one of those blue wires goes to the IGN side of the voltage regulator. This was on there for about ten years with no trouble at all. I took it out and replaced with points because I had improperly diagnosed a problem. I will probably put the Pertronix back on sometime. Hope this helps.
