[FOR SALE] 73-76 drum brake spindles
rich006
Learning as I go
Annapolis, MD
These are the large-ball-joint 1973-1976 drum brake spindles, removed from my daily driver when I converted to disc brakes. I've disassembled everything and wire-wheeled off the grime. $80 plus shipping from Annapolis, MD or you pick up.
I also have the rest of the brake parts. Let me know if you want any of these:
- 10" front drum backing plates
- 1 1/8" front wheel cylinders (need honing, but the original rubber is still good)
- rubber brake hoses (2 years/2000 miles old)
- hard lines from rubber hose to wheel cylinder (original, good condition)
And I have the following items (not pictured):
- inner and outer wheel bearings (2 years/2000 miles old)
- bearing nut, washer, castle
- all drum brake hardware and springs (2 years/2000 miles)
