[WANTED] 73 Plymouth duster gas cap and filler neck
Penstarpurist
Salem
Looking for an oem gas cap and filler neck for our 73 Plymouth duster. I do not have the gas cap at all, and the filler neck I've got is full of rust inside. May try and use a liquid rust remover if I can't find a good one. Thanks.
I have the gas cap and filler neck from a 1972 Duster.
I'll need to pull it to verify condition.
Please let me know if you are interested.
Thanks!
burg
I picked up a couple different necks and caps from a guy local to me one from a space saver duster and one from a swinger. Like a dumb@$$ I forgot to bring my old rusty one. Well the one was too short and was a 4 hole mounting flange. The other one was the wrong angle and neither cap would work on my old filler neck. The mounting holes can be welded in and drilled to match mine, but too short is too short. Even if by only a couple inches. Are the ones you guys have 3 hole or 4 hole mounting. What is the length? I'm fairly sure that I need one from a 73 duster. Thanks.
Mine has the 3 hole mount
The one I have is also 3 hole mounting.
No pictures at the moment.
From a 72 Duster.
Message me if you are interested.
Did you get my e mail with the pictures of the black tube with seal and gold gas cap?
