famous bob
mopar misfit
What are you guys w/ 500" wedge engines running for timing on them ? I have 21 initial, 34 total, all in at 3200 (91 lawnmower gas), w/ max vacuum set at 42. Any body ?
Thanks but not what I`m after. We used to run mech only on the hemi`s at 36 all in at 2800. This is a streetcar, and really likes gasoline, trying to help it a bit.locked mine out, no advance 32-36 depending on what swill I was running.
Engine is a r/b 440/505" wedge, alum heads, .628 lift solid street roller, 254/260 @ .50), 10.3 c.r./ dished pistons, .039 quench, 727, loose 3500 convertor, dana 60/3:73 Detroit locker. 68 fastback form S car, subframes tied, 6 point roll cage ( just to stiffen it up, I really didn`t want a bar----but figured it needed it. 295 65 15 drag radials for the street.) All timing can be set w/ my hand held for the fast 2.0 f.inj.,(1200 cfm throttle body) so changing it is a lot easier than screwing w/ the old style dist. and springs. -- 21 initial , 34 total all in at 3200, max of 44 vacuum advance. engine only has 7-9 " , which is more than I figured, probly due to the gapless rings........ Thanks and , comments welcome ------Bob. ---- Oh, thinking the car weighs around 3000.Timing curves will depend on the package, but for most of the ones I've built, you're about right if not a little too much, too late. These engines don't need a lot of timing to make up for anything so you can run 18-20 initial, and if it's a smaller chamber and quench dish run with tight quench, the total will be closer to 30-32. That leaves some room for the vacuum advance amount, which I will always advise be run on a street car. You should also be able to bring it in a little faster because depending on what your gearing is (most big strokers have mild gearing) you want to have the advance "in" right around your typical cruise-at-50mph rpm. If it's built properly it should be fine with that. If it's a wider quench, or cam too small, you may not be able to do that with 91 from a local pump.
^^^^^^^^^^^^^^^^^^^^^^^I would keep it at 20* initial, set for 32* total, all in at 2500, plus another 12-14* as vacuum. So total with vacuum would be 44-46*. You can bring it in a lot faster, and richen it as you need to but honestly with that convertor I don't think you'll need to do much. Light car, loose convertor, big engine.
Thanks for all the replies ! A little update, I weighed it at the dragstrip last SAT., it weighed 3278 w/ 1/2 tank of lawnmower gas. Didn`t get around to running it, want to put some miles on it first. It seems to like 21 initial, think I might try bringing the total in a little sooner . Thanks again , bobThe quench should be helping you. A huge part of the equation is the mass the engine has to move. You're making it easier: light weight, with gear, and with convertor. So bring it. Watch the plug porcelain with a lit magnifier for any signs of piston material. Also be aware of carb tuning each time you make a timing change. You don't always hear a problem. But we run 91 crap with 10% ethanol in the ground here.
I haven`t had any pinging so far. It tried to not start when I had 22 in it initially, it even balked at 21 Saturday, on a quick hot restart. thanks, bob.You have a fairly big cam for a street engine so your engine will probably want a lot of initial advance. Once you get enough advance in the engine to make it happy then you have to walk a tightrope on the advance curve to keep the engine happy on the street without having it ping when you jump on it hard.
I don't think I've ever had one that came out perfect! Sometimes I just run extra advance for street driving and then twist it back a little bit if I'm going to the track.
u musta missed it. LOL . I`m messing w/ a fast 2.0 set up, all done on the handheld. Sho nice !Is your distributor easy to adjust for advance? Most distributors are hard to adjust as are most vacuum advance cams. That is one reason people just give up on this stuff. If you can adjust everything then I'd put as much initial in it as it will take and then work around the other issues with the springs and slots.
This is a good example of why I'm switching over to EFI. Then the whole pile of parts goes in the trash and I can set my timing curve on the computer just how I want it. No more messing around with springs and slots and vacuum ans and all of that analog crap that is so hard to set up and keep adjusted.
Initial, mid, all in, and total. HAS 8 DEGREES BUILT INTO IT FOR AUTOMATIC PRESET. WERE GETTING OVER MY HEAD W/ SOME OF THIS. lol But so far so good . Think I might try to bring the total in a hair sooner. The engine likes to idle about 1050, also helps control my hot oil pressure.Ahh, I did miss that part. In that case tweak away until you get it perfect. The good EFI systems allow total control over the ignition. Does FAST have a start retard function? The Holley setup has another screen for starting. I think with FAST you just put less timing in if the RPM is less than 500 rpm. That way you can run 20+ degrees of initial timing but only have 12 or 15 while starting. See if you have that option in your software.
I wouldn't worry about putting a lot of total advance in for cruise conditions. If the manifold pressure is low (high vacuum) then you can run more than 50 degrees of total advance. When the manifold vacuum gets close to atmosphere (WOT) then you need to pull the timing back to the low 30 range. But that is easy to do with EFI, just fill out those top rows in the low 30's and then put 45 or 50 in the bottom rows and then just smooth it out. Put 10 or 15 in the left column for starting and you should be really close to done.
