Air filter shootout
Discussion in 'Mopar General Discussions' started by dukeboy_318, Dec 7, 2017.
  1. dukeboy_318
    dukeboy_318 Get off my lawn!!! FABO Gold Member
    22,904
    6207
    Jan 19, 2007
    la la la la
    Local Time:
    3:41 AM
    Hadnt seen/found this posted so I think its worth bringing up.
    Engine Masters on Motor trend did a few weeks backs an air filter setup comparison.
    The base engine is a 496 CI Chevy(gulp) making 750 hp without any filter. Listed below are their combos and the resulting hp those filters will support. + means gained hp, - means losted hp from peak hp of the base engine.
    19: 6.25 x 2.5 mini filter= -145.1 for a max of <300
    18: Single Snorkle mopar big block = -95.8 for a max of 300
    17: Foam filter Velocity stack = - 72.4 for a max of 350
    16: Fly's eye(the triangular eddlebrock set up that is somewhat popular) = -71.1 max of 350
    15: Dual Snorkle Mopar= -53.1 hp max of 390
    14: 10x1.25 short air filter, paper element = -33.5 max of 350
    13: 1.5 inch drop base, K&N 14x3 inch filter with K&N filter lid= -18.8 hp max of 650
    12: 14x3 k&N filter, 1.5 drop base, flat solid lid= -12.7 for a max of 660 hp
    11: Dual Snorkle Mopar with the lid flipped upside down= -11.9 hp max of 640
    10: 14x3 flat base and lid with fram filter= -10.1 for a max of 640
    9: B&B lid with K&N filter= -8.9 for a max of 660
    8: 14x3 with K&N filter lid, flat base= - 7.2 for a max of 660
    7: 14x3 flat base with solid lid, K&N element= -6.6 hp and max of 675
    6: K&N filter lid with 14x3 flat base, element tapped up= -3.5 for 675 max
    5: 4 inch tall, 10 in, flat base, solid lid= -1.2 hp and 750+
    4: Open carb, base line: 0.0
    3: K&N velocity stack with filter lid= 0.9 for a max of 750+
    2: Homemade "Salad bowl" with K&N filter lid= +3.0 hp and max of 750+
    1: Open, no element, Velocity Stack= +5.7 hp and max of 750+
    Just some food for thought.
    • Like Like x 2
    • Thanks! Thanks! x 2
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      1,191
      348
      Feb 7, 2013
      Phila. Pa
      Local Time:
      3:41 AM
      Here's link to the video Enginemasters Air Filter & Housing tests
      It is interesting.
      One key factor: RPM
      Of course now I've forgotton the baseline peak rpm in that test, but I think it was somewhere around 6500 - 7000 rpm.
      If the engine maxes out at less rpm, and has less displacement, then less surface area and more restrictive filter material/screening can be used with no measurable effect on peak Hp.
      That's the basis the guys used at the end to make some rough top of the head estimates of how much Hp each combo they tested could be OK for.*
      One effect of the air cleaner shapes that the graphs would show (if we could see them all) is the impact on the bowl vents. Air flow into the venturi is important, but changing the pressure in the bowls can do both good and bad things. With Holleys on a NA engine, its best to have consistant pressure in bowls. I speculate that the downflow only shapes may have upped the bowl pressure; where as the downflow with sideflow created turbulence and inconsistant pressures in the bowl.
      *For example.
      means this combo made around 700 Hp, 53.1 Hp less than the baseline of 750.
      and it would be fine for any engine up to 390 Hp.
      • Like Like x 2
      • doogievlg
        doogievlg Well-Known Member
        6,082
        1089
        Nov 13, 2007
        Amelia, Ohio
        Local Time:
        3:41 AM
        I saw this and was pretty amazed. The latest one with rocker arms is pretty good too.
        • Like Like x 1
        • dukeboy_318
          22,904
          6207
          Jan 19, 2007
          la la la la
          Local Time:
          3:41 AM
          yep.
        • rumblefish360
          rumblefish360 so close yet so far away
          30,067
          2824
          Jun 21, 2005
          New York, on a Island
          View My Photos
          Local Time:
          3:41 AM
          Break out the salad bowl!
          Weld a scoop to it!
          LMAO
          • Like Like x 2
          • DFX 340 Duster
            DFX 340 Duster FABO Gold Member FABO Gold Member
            1,523
            256
            May 14, 2009
            Orange County CA
            Local Time:
            12:41 AM
            What makes me smile is that an old trick from back in the day was tested such as the "flip the lid upside down". I also remember some 426 Max Wedge guys running velocity stacks and pulling off the elements just before slamming the hood shut prior to their run.
            • Like Like x 1
            • Agree Agree x 1
            • qkcuda
              qkcuda Well-Known Member
              737
              250
              Mar 6, 2013
              Caledonia, Ontario
              View My Photos
              Local Time:
              3:41 AM
              I had noticed that the stock air cleaner was providing a restriction at the track, although I never actually tested back to back. Not hard to figure when you think that the stock lid only provides about 1/2 to 3/4 inch clearance around the bottom. I took and old air cleaner and modified a lid so the filter would be fully open. I run a K&N filter and I just swap lids when I get to the track.
              • Like Like x 4
              • 71DodgeDemon340
                71DodgeDemon340 FABO Gold Member FABO Gold Member
                1,824
                279
                Apr 2, 2011
                Tennessee
                View My Photos
                Local Time:
                3:41 AM
                Personally id keep the second one on all the time. Looks super slick
                :thumbsup:
                • Agree Agree x 1
                • 71DodgeDemon340
                  1,824
                  279
                  Apr 2, 2011
                  Tennessee
                  View My Photos
                  Local Time:
                  3:41 AM
                  Guess im good then with my dual cut out filter housing.
                  I wonder how it would compare to different hood setups though? For instance on my demon the hood scoops direct fresh air right near the opening in the housing, wouldnt that allow more airflow than a hood without fresh air ports even if you were running a standard open side filter?
                • dukeboy_318
                  22,904
                  6207
                  Jan 19, 2007
                  la la la la
                  Local Time:
                  3:41 AM
                  Ram air doesn't make a huge difference. A couple hp at the most. And simulating that on a dyno is a challenge unless that dyno happens to be in a wind tunnel. The biggest effect is gonna be from the cooler, slightly denser air charge I would think.
                • fratzog lover
                  fratzog lover FABO Gold Member FABO Gold Member
                  9,897
                  5372
                  Jun 7, 2013
                  Maple Shade New Jersey
                  Local Time:
                  3:41 AM
                  I was a lid flipper back in the day. I even did it on dads 75 C1500, although the moaning Quadrajet didnt have much smog strangled cam to work with.
                • Tooljunkie
                  Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                  2,426
                  1533
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  2:41 AM
                  I cut up an air cleaner. All i could find at the time.
                  • Like Like x 1
                  • sireland67
                    sireland67 Well-Known Member
                    6,515
                    761
                    Oct 27, 2010
                    WV
                    Local Time:
                    3:41 AM
                    From the results of the test, it looks like the diameter of the air cleaner is more important than the height.
                  • dukeboy_318
                    22,904
                    6207
                    Jan 19, 2007
                    la la la la
                    Local Time:
                    3:41 AM
                    Yep and a flat base definitely was
                  • Johnny Mac
                    Johnny Mac www.blueprintengines.com FABO Vendor
                    2,125
                    438
                    Jul 10, 2010
                    OHIO
                    View My Photos
                    Local Time:
                    3:41 AM
                    I love the engine masters series (Especially love all the BluePrint Engines they run) haha.
                    Nice guys in person, down to earth, and alot of good knowledge. I enjoyed the header smashing eposode. Especially since I replaced a set of mildly dinged headers back in the day b/c of all the hp they must have been robbing from my mighty 318. Lol ahh to be 16 again!
                    • Like Like x 3
                    • fratzog lover
                      9,897
                      5372
                      Jun 7, 2013
                      Local Time:
                      3:41 AM
                      I would love to meet Steve one day.
                    • rumblefish360
                      30,067
                      2824
                      Jun 21, 2005
                      View My Photos
                      Local Time:
                      3:41 AM
                      Myself as well. I would always like to meet those fellas one day.
                      Anyone remember the prior thing Dave F. did?
                      Suck Squeeze Bang Blow?
