Good idea that you are running separate 8 awg wires thru the firewall. That is known as the "fleet bypass", which the factory did for some cars like taxi and police. I would use just the single big fuse shown. You can put it either in the engine bay or under the dash, wherever easy to get to and won't get too hot. I wouldn't bother with the smaller individual fuses you show since I think all those circuits have fuses in the factory fuse box.
I 2nd 273's suggestion to add relays to take the load off the switches and bulkhead terminals, where possible. I wired a relay on the key switch ACC wire, so the switch just actuates the relay coil. I also use a relay for "blower high" position since otherwise those switches like to melt, and the 5-button climate switch in my 69 Dart was expensive. Under-hood, I have relays for headlights, AC compressor, ignition. I used a relay box from a 91-94 Jeep, which also replaced the factory relays (horn, starter). Many people wire individual relays for head-lights to get brighter lights, but probably not necessary if your switches and connectors are good, unless you install HID bulbs.
My prior posts give calculations for the ammeter diode bypass. The diodes act as "variable resistors". They have almost infinite resistance at low current flow, so shouldn't affect the ammeter reading at low current. As current increases, they conduct much more, shunting current around the ammeter direct to the battery to protect it. In my 65 Newport, I measured 0.75 V drop across my ammeter at max alternator output (~50 A, w/ no diode shunt). At that point, the diodes I used in my Dart (Schottky type) should conduct strongly. Tested in my Dart, the ammeter goes no more than 50% scale with full 12 V on the square-back alternator, but I tried only at idle. The way you show it wired is correct. The main design consideration is putting the diodes where they have a good heat sink, maybe either right on the alternator or at the battery. Power dissipated will be P = i * dV, where dV is the voltage drop which you use the charts in the diode datasheet. Expect ~50W max dissipation. Of course, insulate all exposed metal since at battery voltage.
