dragracer501
Member
I have a 1969 dodge dart and a few weeks ago I was making a pass and about half way the car shut off and hasn't restarted. its not a fuel issure definetly ignition related, I bypassed the bulkhead connector because I thought one of the fusible links went bad and it melted the connector so I made a jumper wire through the firewall with a 30 amp fuse in it. I installed my old ignition box and the car ran but it ran like crap then I hit the gas and it blew the box literally blew a little hole in it, so I ordered a new box and installed it started the car then I was under the hood and the fuse I previously mentioned started to glow and it blew the fuse and im guessing the ignition box as well. im lost the car has all factory wiring so I don't know if theres a ground that went bad and caused all this. any help where to start or any knowledge of ground locations would be awesome I wanna drive my car!!
