Cold-Case Radiator Review
kris hines
Delaware
So after being carless and poking a hole in my factory radiator I started looking around at the aftermarket offerings. Cold case was one brand that had not hear much about within the mopar community but doing some looking around I found a few reviews in a few different chevy forms. All the reviews I read were very good to excellent for cold case. So I decided to give them a try, so here is my install and thoughts on the cold case 22” A-Body radiator for a 68 barracuda with a 340.
The radiator arrived.
Very nice shine out of the box, if you are looking for a highly polished finish it wouldn’t take much work to get it out of this radiator. I prefer a brushed look so I will be going over it with a scotchbrite pad
A few more pics of the radiator next to the stock one.
Now for the installation.
Test fit showed the lower mounting holes were off approximately ¼ inch on both sides.
Trimmed up both sides as marked:
Trying to get the radiator down low enough I knew I had to trim and reshape my lower radiator support. A closer inspection I found that some point in my cars life it had sustained a lower impact as the upper support brace only had 1 bolt hole lined up as well as the brace from the lower support to the K member was bent.
If my car did not have this damage I am fairly confident that trimming the lower radiator mounting holes would have been the only modification I needed to make.
Installed:
Over all I am very happy with the quality and finish of this radiator. Joe and Eric at cold case were great to work with as well. I am still waiting for my electric fans to come in as well as get the fuel injection setup tuned in. So I have no real “performance” number to throw out. I did get the car started today for the first time, with 5 min of running with no fans my temp was at 180*. Will update this thread with the progress as I go. I have plenty more pics if anyone needs any.
Looks nice, wish they made these for the early a. I had a champion and that lasted 1 1/5 before leaking from 3 spots.
Jake
looks pretty good. I like the look of the formed tanks over the welded ones. Looks like the hose locations are moved slightly and for the guys that want to use the factory shroud are the nut-serts in the same location as the stock rad?
the nut-serts are a bit off. stock radiator i measure center to center at 13 3/8ths vs cold-case 14 1/8th. the top hose location is moved about 3" out from stock location. But i agree, i do like the formed tanks much better than the welded ones!
