Crash Beam
Discussion in 'Mopar Body and Trim' started by SpeedThrills, Sep 12, 2017.
  1. SpeedThrills
    SpeedThrills Well-Known Member
    1,104
    62
    Jun 3, 2008
    Very South Jersey
    Local Time:
    3:14 PM
    What year did they start using them? My 74 Dart Sport has them. I'm thinking they started in 73? I'm going to look at a pair of 72's, if they don't have them. I'm looking to lose the weight. (Car will have a roll bar.) The 72's are in better shape than mine, too.
    While I'm at it, what do they weigh? Can they be removed? They appear to be built into the seam where the inner and outers are assembled. If so, I guess it would be easier to weigh the entire door and compare them.
  2. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    12,957
    1058
    Jan 16, 2005
    las vegas
    View My Photos
    Local Time:
    12:14 PM
    My 73 Duster does not have them.....
  3. rustycowll69
    rustycowll69 Well-Known Member
    937
    261
    Feb 19, 2016
    Pacific northwest
    Local Time:
    12:14 PM
    good question. I don't know for a fact, but I believe I read that the e-bodies had them from the get-go.
  4. Faster74
    Faster74 Banned
    148
    8
    Jul 21, 2015
    Ky
    Local Time:
    9:14 AM
    74 duster was 1st year they had the 5 mph bumper ,suppose to spring in then back at 5mph with minimum damage, just put a 73 taillight panel on my 74, there was a small place at each spring for the beam support that the 73 didnt have, was going to remove beams on it , found out that 73 bumper braces had to be added , since all my under side braces and brackets were without rust, decided to leave mine as original.
  5. mbaird
    mbaird mbaird
    2,509
    424
    Dec 10, 2005
    boise, Id
    Local Time:
    1:14 PM
    I think he may be referring to the door crash beams... and that was 73 or earlier because a I removed them from a 73 340 car I had.
    My 69 Swinger does not have them
  6. Dartswinger70
    Dartswinger70 Well-Known Member
    955
    207
    Sep 20, 2005
    A train bound for nowhere
    View My Photos
    Local Time:
    3:14 PM
    What is a crash beam? is it a new flavor of jim Beam?!?
    • Agree Agree x 1
    • SpeedThrills
      1,104
      62
      Jun 3, 2008
      Very South Jersey
      Local Time:
      3:14 PM
      Yeah, lol, I forgot to mention the word "doors", after I said I'm going to look at a pair of 72's.
      For those unaware, they run the length of the door, on the skin side, inner.
      I know from working on Fox Mustangs, that they're heavier than you'd think. I believe about 18 lbs. each.
    • mbaird
      mbaird mbaird
      2,509
      424
      Dec 10, 2005
      boise, Id
      Local Time:
      1:14 PM
      Maybe 8 lbs on an A body IIRC...
    • jos51700
      jos51700 Well-Known Member
      3,574
      540
      May 24, 2009
      Bel-Ray
      Local Time:
      2:14 PM
      They're noticeably heavier. I think they started in '73.
    • mderoy340
      mderoy340 Well-Known Member
      1,590
      305
      Aug 2, 2012
      Melbourne FL
      Local Time:
      3:14 PM
      73 Dart Sport has them. 73-76 doors are different in other ways.
      • Thanks! Thanks! x 1
      • zkx14
        zkx14 Duster De-ruster FABO Gold Member
        13,147
        5335
        Dec 23, 2012
        South Central PA
        Local Time:
        3:14 PM
        Interesting...I wonder if that is a Dart vs Duster or more likely an early 73 vs late 73. I know Duster 73 glass is one year only, but don't know what all changes were made in the doors before or after. Like many other changes, prob happened mid year when they ran out of the old parts or got supply of new ones. Not by the calendar.
      • Dartswinger70
        955
        207
        Sep 20, 2005
        View My Photos
        Local Time:
        3:14 PM
        I am into reassembling the doors on my 70. Not much side impact protection at all, just a door shell with window regulator.
      • SpeedThrills
        1,104
        62
        Jun 3, 2008
        Very South Jersey
        Local Time:
        3:14 PM
        I bought the '72 doors today. (build date 5/72)
        The drivers door, complete w/ mirror, but no hinges weighs 73#.
        The '74 drivers door (build date 5/74), also complete with the same type of mirror, but no hinges, weighs 84#.
        The '73 and up have a different window regulator, so I don't know if that is part of the weight difference.
        Woo hoo! I lost 22# today!!
      • Ol'forest
        Ol'forest Well-Known Member
        286
        13
        Apr 6, 2009
        Hamilton, New Zealand
        Local Time:
        9:14 AM
        If you could totally remove the beams i.e. cut them out completely, the 73-76 door would be slightly lighter, not by much. The interior handle assembly and inner door framing is slightly lighter. Also if you swap doors you will need to swap to the 70-72 rear 1/4 window steel inner panels to match the doors, which adds a little weight, again not much though. If it was me I would attempt to cut the beams out, but then again I have no spare 72 and earlier doors nowadays.
