discontinued mp roller cam P5249663 info
mderoy340
Melbourne FL
Anyone have any experience with this discontinued 360/300hp crate motor cam replacement kit P5249663 274/264 duration .433/.430 lift. Maybe someone has an old mp catalog or cam card?
I'll have to check the block tomorrow. The info I posted for duration and lift is from the Mopar Engine book 9th edition.
I don't know, but there are cams a lot better than that one out there. I think the 360/300 crate cam was basically a stock truck cam.
The 2000 catalog list the cam as follows:
Advertised Duration: 250/264
Overlap: 37
Centerline: 110
Lift .385/.401
Recommended Spring: P5249464
Comments: Service for 300 crate motor. (will not fit stock 5.0/5.9 engines)
I don't know where the 5.0 comes from, but it's there in the catalog. On the other hand, my eyes may be going bad.
It's most likely a typo. If you use the keypad and miss the "2" you can hit the "0". So the 5.2 then becomes the 5.0....
Or what some people call "fat fingers"...
