[Found!] Distributor cores again
This one?
I have one from my 71 318...does not have points in it.. has vacuum advance
Assume you are looking for LA engine only?? Local yard probably has 4 or 5 in it's distributor bin. Yard is on life support, will not be around in a year or two. And I have an early seventies slant six one, stored inside, probably just needs points and lube, to drop in a customer's car.
Did you want the one I posted for LA points style?
