Duralast brake shoes
Discussion in 'Brakes for your Classic Mopar' started by DusterDaddy, Mar 20, 2017.
  1. DusterDaddy
    DusterDaddy sledgehammer mechanic FABO Gold Member
    1,642
    500
    Apr 21, 2011
    Holmdel, NJ
    View My Photos
    Local Time:
    11:17 PM
    Has anyone ever seen a wheels cylinder rod pitch down so much?
    Car is a 74 Duster with 10 drums in the back. We put together with the long spring on the front shoe as well and switched to the short spring thinking it would help the angle of the rod. No such luck
  2. 72Dart6pack
    72Dart6pack Well-Known Member
    558
    293
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    11:17 PM
    Your rear shoe does not look to be seated on the pin.
    • Agree Agree x 2
    • eeka440
      eeka440 Well-Known Member
      49
      13
      Sep 16, 2010
      Ontario Canada
      Local Time:
      10:17 PM
      Rear shoe not seated properly. Check the park brake cable.
    • DusterDaddy
      1,642
      500
      Apr 21, 2011
      Holmdel, NJ
      View My Photos
      Local Time:
      11:17 PM
      will do
    • DusterDaddy
      1,642
      500
      Apr 21, 2011
      Holmdel, NJ
      View My Photos
      Local Time:
      11:17 PM
      Ok the side with the angled down cylinder rod in the pic I posted is the front shoe
    • Bad Sport
      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
      28,277
      2548
      Jun 12, 2010
      The Wolverine
      Local Time:
      11:17 PM
      Post a pic of the whole thing.
    • DusterDaddy
      1,642
      500
      Apr 21, 2011
      Holmdel, NJ
      View My Photos
      Local Time:
      11:17 PM
      As soon as I get home. Thanks
    • Bad Sport
      28,277
      2548
      Jun 12, 2010
      The Wolverine
      Local Time:
      11:17 PM
      One thing pops out to me, the rods look like they are pushed out to their max. You may need to open the bleeder and get those pushed in some. The one shoe on the right in the pic doesn't look seated at the top like it should be.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • RedFish
        RedFish Well-Known Member
        20,676
        729
        Sep 5, 2007
        Local Time:
        10:17 PM
        My guess... one side or both of that wheel cylinder is stuck. The return spring(s) should push the fluid/piston back. If opening the bleeder relieves fluid pressure and wheel cylinder compresses next suspect is the flexible fluid line above the differential.
      • DusterDaddy
        1,642
        500
        Apr 21, 2011
        Holmdel, NJ
        View My Photos
        Local Time:
        11:17 PM
        There are no brakes lines installed yet
      • RedFish
        20,676
        729
        Sep 5, 2007
        Local Time:
        10:17 PM
        Ok then, something amiss with that wheel cylinder is still my guess.
      • DusterDaddy
        1,642
        500
        Apr 21, 2011
        Holmdel, NJ
        View My Photos
        Local Time:
        11:17 PM
        I'm going to get after it in about an hour and figure it out
        It's the same thing on both sides so it must have something to do with you not being seated properly
      • DusterDaddy
        1,642
        500
        Apr 21, 2011
        Holmdel, NJ
        View My Photos
        Local Time:
        11:17 PM
        Here is the whole thing we put bith yellow springs oninitiall. last night I put the short spring on the front shoe to see if it would pull it up to make that piston rod straighten out but it did not. You can see the front shoe is not sitting as close to the top pin as the rear shoe is. It's like this on both sides of the car.
      • zkx14
        zkx14 Duster De-ruster FABO Gold Member
        9,826
        2810
        Dec 23, 2012
        South Central PA
        Local Time:
        11:17 PM
        Is the ebrake cable pulling it out of whack?
      • DusterDaddy
        1,642
        500
        Apr 21, 2011
        Holmdel, NJ
        View My Photos
        Local Time:
        11:17 PM
        I'm not sure Keith. I had poor Al here yesterday with no brake tools putting them together. I stopped at Advance Auto and bought some cheap brake tools. Today. I'm going to take a whack at it in a few minutes. I'm real sure I can solve it after Al did the heavy lifting. I do think the longer spring belongs on the front as well
      • dirty white boy
        dirty white boy Well-Known Member
        539
        184
        Dec 15, 2012
        stoneville n.c.
        Local Time:
        10:17 PM
        duralast shoes,..are thay the right shoes?? do thay match what was on the car??? most time i get duralast i gotta make 2nd trip to get the right shoes...
        • Agree Agree x 1
        • zkx14
          9,826
          2810
          Dec 23, 2012
          South Central PA
          Local Time:
          11:17 PM
          this shows short spring front
          • Like Like x 1
          • pishta
            pishta It's a gift.... FABO Gold Member
            9,185
            581
            Oct 13, 2004
            Tustin, CA
            View My Photos
            Local Time:
            8:17 PM
            push the right side shoe up.....look at top where spring eye is, the bottoms of the shoes should be even, your 1/4 off
          • mbaird
            mbaird mbaird FABO Gold Member
            1,966
            196
            Dec 10, 2005
            boise, Id
            Local Time:
            9:17 PM
            Is that a Russian service manual ?
            • Like Like x 1
            • DusterDaddy
              1,642
              500
              Apr 21, 2011
              Holmdel, NJ
              View My Photos
              Local Time:
              11:17 PM
              Ok. The problem is the hole in the front shoe for the retainer pin and spring are different from the old shoes. To put the top of the shoe in the proper position the retainer pin would be angled up about 30 degrees or more. I'm going to get different brake shoes.
              What should I get?
              • Agree Agree x 2
              • diymirage
                diymirage HP@idle > hondaHP@redline FABO Gold Member
                9,049
                1781
                Oct 12, 2012
                michigan
                Local Time:
                11:17 PM
                look at the pin where the adjuster lever pivots on
                did they come pre-installed?
                if not, you may have two fronts or two backs
                but to be fair, it looks like the pistons are too far out
                check the cylinder
              • pishta
                9,185
                581
                Oct 13, 2004
                Tustin, CA
                View My Photos
                Local Time:
                8:17 PM
                I just put in the proper perspective so it would match up. Still looks wonky at yellow circle. Do the arcs line up, like did you get a 9 and a 10? Here is another reference pic: Another observation...is the cocked strut seated in the piston or is it hung up on the top edge?
              • diymirage
                9,049
                1781
                Oct 12, 2012
                michigan
                Local Time:
                11:17 PM
              • Bad Sport
                28,277
                2548
                Jun 12, 2010
                The Wolverine
                Local Time:
                11:17 PM
                Sure looks that way. Nothing wrong with Duralast in my mind, take the old shoes with you along with those new ones, and see if they gave you the correct ones. If they come up with a different number, use the old shoe to match up to the new one, holes, length, width etc.
              • DusterDaddy
                1,642
                500
                Apr 21, 2011
                Holmdel, NJ
                View My Photos
                Local Time:
                11:17 PM
                I have it at a shop now and they say the wheel cylinder is too small. Anyone know what the right wheel cylinder part number for a 8.25 rear with 10 drums?
