Engine shakes under acceleration
standup303
Colorado
360LA the engine seems to shake under acceleration. It’s a hard vibration almost. As soon as it hits about 2,000 rpm and about 1/3 throttle it starts. Do you guys have any tips?
If it does it in park or neutral, it's very likely an imbalance of some sort. The 360 is externally balanced from the factory. I would look for maybe evidence the balancer has slipped. Maybe get a good picture of the balancer and post it.
Is it smooth at idle & then rough at 2000? If so, I agree with above.
If rough everywhere, I would looking at anything that causes a variation between cyls: fouled spark plug, burned valves, wiped lifter/lobes, etc
Is that stall rpm?
Is it better when cold?
Is it worse with more throttle?
if yes times 3, then check your firing order, and separate numbers 5 and 7 wires. If those are ok, then disconnect the Vcan and roadtest again. If still bad, check the Power-timing beginning at whatever rpm it starts . Make sure TDC of the piston is TDC on the balancer.
Pre-Ignition going to detonation, can feel like that. Detonation must be Eliminated.
Was it right and now has a problem. Also see if dist loose and turned
Under heavy load as if hard acceleration? possible something is loose causing engine, trans, exhaust contacting body or frame causing vibration? Possible engine misfire under load? try lightly power braking engine slowly up to stall speed or 2,000 rpms and see if you can feel the miss, just don't overheat the trans fluid.
If parked and I Rev to 2k I can feel it. But not at idle. I checked the balancer to see if it felt loose at all and seems good. I can’t get a good eye on whether it slipped or not. I’ll have to dig in more this weekend.
I will give this a try. Thank you.
Yes smooth at idle.
Is that stall rpm?
I’m not sure on stall. The car is new to me. The shake comes around whether cold or warm. Definitely gets worse with more throttle. I’ll try this out this weekend.
Put a timing light on it. You'll spot it real quick if you cannot see the timing mark on the balances, or if the mark is WAY off the pointer.
Yup. Classic imbalance vibration.
