Grille brackets 71 Demon
Dubob
Ohio
Once again I'm here for some help. I need a picture of the radiator support with the brackets that the grille attaches to for my 71 Demon, I'd assume the Dart would be the same as it uses the same grille. Looking for the shape as well as location. I looked in my FSM and there's no clear pictures. Another thing trying to figure out with buying a project in work. Thank you.
These are the best pictures I can get for tonight.. They are sheet metal L brackets that attach to the fender and tie into the grille tabs. There are only two of them.. The grill contains the rest of the mounting tabs built in.
Thank you for the reply. I will have to dig some more to see if I have those brackets. Still trying to figure out what the tabs on the grille attach to on the radiator support.
The middle tab on the grille attaches to the hood latch support. The rest of the grille attaching points are on the fenders. Here is a better picture of the tabs on the grille. I had to remake mine since they were all missing.
Gotcha. Thank you very much. I guess if I'd of thought about it and looked I would have got there. The car was apart when I bought it so I've never seen it all together. Again thank you.
