jos51700
Green Bearing thread connoisseur
Harbor Freight fuses...
The second from left on the bottom row got hot enough the plastic melted completely off (and melted the fuse block too), and the fuse was still intact and carrying enough current to melt a bunch of wires! (It was a 10Amp circuit, but it had a 15 amp fuse, carrying a 20Amp load). You can still see the blade of the fuse in the holder, and a blue gob of plastic at the bottom of the fuse block.
The yellow fuse you can see is all puffed out and melted, too, and it's the proper fuse for its' circuit. It melted, blew a big plastic bubble, and it's not blown, either!
Saving a buck on fuses (exacerbated by shoddy wiring practice for accessories) nearly cost this guy a full-custom Kawasaki Mean Streak, and will cost him a $300 wire harness for sure!
I know that our old Mopars don't use many of these fuses, but you can get all kinds at HF, and a lot guys run modern wiring. This is one HF item to skip!
