[FOR SALE] Harley-Davidson Panhead Chopper
Brad4406
Fairborn, OH
Harley-Davidson Panhead Chopper. Rigid Paughco frame with 6" over Paughco wide Springer front end. 79 ci (stroked to 4.25") Panhead engine with 5100 miles since rebuild. 4-speed trans with 200 miles since rebuild. STD dual plugged Panheads with Shovelhead spigots; allows for running Shovelhead bolt-on exhaust instead of Panhead pinch-fit exhaust. Other parts: S&S Super E carb, 3" open primary belt drive, converted to 12 volt electronic ignition system with dual coils, disc brakes front and rear, 21" laced front wheel, Mustang pillow seat, and 5 gallon tanks. New paint and air-brushed flames on tanks and front fender. Kick start only, but tuned well; usually a one or two kicker. Clean Ohio title as 1956 Harley-Davidson FL.
This is a true chopper, i.e., rigid frame, kick start only, Springer front end, no turn signals, etc... If that's not what you're looking for, then please look somewhere else. This is not a basket case and therefore not priced as one; $12K. A reasonable offer will not be refused, but no trades will be considered. Located in Lebanon, OH.
