I'm running a '74 225 from a Charger in my '65 Dart, and up until recently, I was running a decent Holley 1920 on it. Unfortunately, the casting on the metering block for the power enrichment arm wollered out, and is no good now.
So, I rebuilt the 1945 that came with the engine, and I've got a few questions. It had a 63 jet in it. Using my wideband, I've found that it cruises at around 15-15.3:1, and is in the 13.5-13.7 area under full throttle. Under light to moderate acceleration, it leans way out to 16-16.5:1 and stays there until I back off again. I can obviously feel this as a slight surge when accelerating.
The idle mixture screw also is backed out to 3.75 turns out from seated to get the lean-best idle.
The engine has 18.5 inches of steady vacuum at idle, and I have set the idle to around 725 RPM.
So, should I jet this thing up even more? It likely is the '74 version of the carb, which doesn't seem to have a good reputation.
Thanks for any insight or input...My gut feeling is to throw a 64 jet in there and see how it reacts, but changing jets in a 1945 is a little more of a pain than in a 1920.
