How much more tire if moving springs but NOT mini tubbing?
Discussion in 'Tires and Wheels (Mopar Hubcaps Too)' started by Mopar-Man, Mar 20, 2017.
  1. Mopar-Man
    Mopar-Man Big Block Better Burnout
    1,031
    624
    Oct 10, 2009
    Orlando, Florida
    Local Time:
    7:06 AM
    Just wondering if anyone has some photos? I don't need much more room and I think moving the springs would get it done and still keep my folding seat/custom baffle board intact.
  2. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    7,488
    1598
    Nov 28, 2008
    NorCal
    Local Time:
    4:06 AM
    If you're talking about a 3" spring relocation, there's no point in doing it without a mini-tub. The 1/2" spring offset from Dr. Diff gets you all the room you can use with the stock wheel tubs. Once you've installed that the tubs are the limiting factor. The offset hangers and shackles just bolt in, moving the spring perches is the only welding for that one, much easier than the 3" relocation.
    This a duster we're talking about? 275's will fit with the stock spring locations. If you do the 1/2" offset and are willing to trim or roll the quarter lips back another 1/2" you can run 295's. That's what I run on my Duster. 1/2" spring offset, ~1/2" trimmed off the quarter lips, and 295/35/18's on 18x10's. Thats the biggest that will fit inside the wheel tubs, only way to go bigger would be to hang thr tires out of the quarters and jack up the ride height, or do the full 3" relocation and mini-tub.
    • Thanks! Thanks! x 1
    • roccodart440
      roccodart440 Well-Known Member
      4,250
      3400
      Apr 19, 2010
      Local Time:
      7:06 AM
      I'd go this route and get a license plate that says "classy"
    • 72bluNblu
      7,488
      1598
      Nov 28, 2008
      NorCal
      Local Time:
      4:06 AM
      :rofl:
      • Like Like x 2
      • UDUST81
        UDUST81 Well-Known Member
        431
        110
        Jan 5, 2014
        Des Moines IA
        Local Time:
        6:06 AM
        I fixed it for you :thumbsup:
      • dirty white boy
        dirty white boy Well-Known Member
        718
        262
        Dec 15, 2012
        stoneville n.c.
        Local Time:
        6:06 AM
        sounds like joe dirt,..buffin his chit out!! lol
        • Like Like x 2
        • roccodart440
          4,250
          3400
          Apr 19, 2010
          Local Time:
          7:06 AM
          Brother I'm telling you. Rubber for days...
          • Like Like x 3
          • Agree Agree x 1
          • UDUST81
            431
            110
            Jan 5, 2014
            Des Moines IA
            Local Time:
            6:06 AM
            • Like Like x 4
            • roccodart440
              4,250
              3400
              Apr 19, 2010
              Local Time:
              7:06 AM
              check out that header to ground clearance. /\ /\
            • kris hines
              kris hines Well-Known Member
              113
              68
              Jan 2, 2017
              Delaware
              Local Time:
              7:06 AM
              Lmao!!! Love it!!
              • Like Like x 1
