ID Rear End Help
Discussion in 'Transmission and Drivetrain Tech' started by Boedighw, Feb 16, 2017.
  1. Boedighw
    Boedighw Well-Known Member
    128
    10
    Jun 18, 2015
    Oregon
    Local Time:
    7:58 AM
    Guys,
    Good evening, working on a '72 Duster. Needing to know if I need to upgrade the rear end. The car is in storage right now but snapped a picture of the center section. So what rear end is this?
    I'm struggling because there is some sort of adapter or spacer that is pushing the wheel out causing it to rub when I go over bumps. Is the spacer to look cool? Or is it an adapter since they did a large bolt pattern disc swap on the front? I believe all 8 1/4 were large bolt pattern so why the aluminum something's on the wheel?
    Thanks for your help!
  2. Kern Dog
    Kern Dog Well-Known Member
    2,090
    1020
    May 23, 2010
    Granite bay CA
    Local Time:
    7:58 AM
    That does look like the 73-76 8 1/4 axle. It is a very good axle and worth keeping in place. The spacers that you mention may be there as you mentioned, just to move the tire out wider for a more aggressive stance. Most Duster/Demon/Dart Sport cars look funny to me when fitted with stock tires and wheels. These cars are wider at the rear wheelwell than the same year Dart or Valiant even though they use the same rear axle. The car has a long body overhang at the tire like a 68-70 Charger with stock tires.
    I have put 68-70 B body 8 3/4" rear axles in many Dusters. These axles are 3" wider than the stock and help the car look better even with a 7" wheel. Here is one example of a moderate sized tire on a Duster with a 68 Coronet axle:
    • Like Like x 1
    • RustyRatRod
      RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
      44,155
      7521
      Jun 7, 2010
      Georgia
      View My Photos
      Local Time:
      10:58 AM
      That's an 8.25.
      • Like Like x 1
      • Boedighw
        128
        10
        Jun 18, 2015
        Oregon
        Local Time:
        7:58 AM
        Not caring about original or trends does it make sense to keep this over a 8 3/4 swap? Planning a 440 build that will be about 400hp ish (essentially magnum with new style cam, intake, headers)
      • Kern Dog
        2,090
        1020
        May 23, 2010
        Granite bay CA
        Local Time:
        7:58 AM
        I'd look for a 68-70 B body 8 3/4" axle. The 8 1/4" is tough enough for the small blocks and even mild big blocks. Anything that will see some hammer time will benefit from a more durable axle. Also, chances are this axle is a one legger. Why add Sure Grip to an axle that was never put behind a 440 anyway?
      • Kern Dog
        2,090
        1020
        May 23, 2010
        Granite bay CA
        Local Time:
        7:58 AM
        Where in Oregon are you? Anywhere near Sandy? Wildcat auto wrecking surely has a few of those B body axles in stock.
      • Leadfoot
        Leadfoot Jane Goodall of the N&P forum
        17,380
        1117
        May 21, 2009
        Severance Colorado
        Local Time:
        8:58 AM
        You're not going to hurt that thing. There's a lot of variables like converter, gears, tires, and weight but those things are a lot tougher than people give them credit for being.
        • Agree Agree x 2
        • RustyRatRod
          44,155
          7521
          Jun 7, 2010
          Georgia
          View My Photos
          Local Time:
          10:58 AM
          The 8.25 will be just fine.
          • Agree Agree x 2
