Install Windshield on 69 Dart Sedan
Discussion in 'Mopar Body and Trim' started by blewbyoutobad, Mar 20, 2017.
  1. blewbyoutobad
    blewbyoutobad Well-Known Member
    591
    40
    May 23, 2010
    Missouri City, TX
    Local Time:
    6:15 AM
    All, I've read many opinions on how to install glass my eyes are bleeding and I'm really confused. I am out in the country so no chance of getting a glass shop here. I have done one in an A100 but it was 15 years ago. I used the rope with the gasket on the windshield. Can anyone here cut through the chase and really tell me their experiences for the best way. Also I dont remember any butyl on the windshield when it came out. Can it be applied later if there is a leak?
    Thanks FABO
  2. Dragonsteel
    Dragonsteel Active Member
    39
    18
    May 12, 2015
    Missouri
    View My Photos
    Local Time:
    6:15 AM
    I know on my Dart when I installed the back glass I put the rubber on the glass and roped it in from inside the car. On the front windshield I put the rubber in the car without the glass in it, then I set the glass in starting at the bottom center and working upwards to the top center. I worked the glass in to the rubber with a flat blade screw driver, but be very careful as it's easy to chip the glass. You can use a little soapy water on the rubber to ease it over the glass. I did not use any sealer as I do not plan driving my car in rain or thru car washes.
  3. harrisonm
    harrisonm Well-Known Member
    1,400
    629
    Jan 16, 2005
    Topeka, KS
    Local Time:
    12:15 PM
    I used the string in the gasket method for front and back on my 69 Barracuda. Put the glass in the gasket, and wrap heavy twine all around in the groove in the gasket that will fit on the car's lip when installed, overlap the twine's ends by about 6" and lube the twine up with some soapy water. Oh, and a nice warm gasket works best; so lay it in the sun for a while first. Pull twine through from inside the car very slowly.
  4. DusTed74
    DusTed74 Well-Known Member
    878
    90
    Nov 12, 2006
    Wisconsin
    Local Time:
    6:15 AM
    I'm planning on doing this soon myself so I can use all this info too.
    Ted
  5. pauly v.100
    pauly v.100 Well-Known Member
    3,392
    140
    Sep 28, 2005
    honolulu, hi.
    View My Photos
    Local Time:
    2:15 AM
    • Like Like x 1
    • blewbyoutobad
      591
      40
      May 23, 2010
      Missouri City, TX
      Local Time:
      6:15 AM
      Thanks all, I did it last night by myself with the gasket on the frame. It worked out well, with the exception that I should have streatched the top of the gasket first so it fit better. My 6" pocket comb worked really good.
      • Like Like x 1
      • Dragonsteel
        39
        18
        May 12, 2015
        Missouri
        View My Photos
        Local Time:
        6:15 AM
        Yes proper tools are recommended, I'm not advocating the use of the screwdriver
        for windshield installation, I just honestly stated how I accomplished the install on my Dart.
      • DrCharles
        DrCharles Well-Known Member
        279
        68
        Jun 7, 2012
        West Plains, Mo.
        Local Time:
        6:15 AM
        I'm going to use the factory-recommended butyl sealant. For the front I can apply it between the gasket and the frame, especially at the bottom where there is not a full lip.
        What about the rear window? Seems like it'd be awful messy to put butyl on the body lip and then rope the glass from the inside. Could I just use a needle tip and squirt it under the seal afterwards?
      • blewbyoutobad
        591
        40
        May 23, 2010
        Missouri City, TX
        Local Time:
        6:15 AM
