LA roller cam motor/ magnum heads??????
dirty white boy
50 yr old Juvenal delinquent
stoneville n.c.
got a 85 318 roller cam motor and thinking bout the magnum heads bang for the buck!! will the LA roller lifters pump oil up to valve train like the magnum lifters do or would i hafta buy magnum lifters to get it done???
I'd like to know as well.
At least Magnum lifters are plentiful at the u-pull.
The ones that came with mine do oil..........LA roller......I bought EQ heads......but it was rebuilt by an unknown rebuilder (I bought it new from a private party who never got it into his van) ANYhow, they oil, but as they are new replacements and not OEM, hard to say
the stock roller lifters that i got with my LA roller cam Block will do pushrod oiling...if you use hollow pushrods. So the answer to your question is yes.
Michael
NO! My 89 Fifth Ave which is a roller LA 318 does NOT have provisions for oiling head thru push rods... simply check for the oil hole on top of the roller lifter which mine does not
Left lifter magnum roller.... right is LA roller
