Large O ring on dizzy? Rubber or other
Discussion in 'Slant 6 Engines' started by gdizzle, Nov 25, 2017.
  1. gdizzle
    gdizzle Well-Known Member
    798
    85
    May 25, 2015
    los angeles
    Local Time:
    8:12 PM
    I just removed and replaced the Electronic Dizzy on my Slant 66 dart. The hold down bar seems to be held (lightly) in place by a large O ring. This O ring is very hard, and has a crack in it. My questions: Is this supposed to be a rubber O ring? Or a hard o Ring (like metal). Then there is also a small narrow slot on the shaft that has a thin rubber O ring, which is rubber. But it is much narrower that the actual slot. Is the wrong size?? BTW this dizzy is a 1970s Chrysler NOS with vacuum pod.
  2. slantsixdan
    slantsixdan =..=
    5,780
    824
    Jan 7, 2007
    Vancouver BC
    Local Time:
    6:12 PM
    The large O-ring doesn't hold the hold-down plate; that plate is held to the distributor with a bolt and to the block with another bolt. The large and small rubber (yes, they're rubber) O-rings are oil seals. The small O-ring being narrower than the distributor shank groove is normal.
    Sounds like you're due for new O-rings. Use good quality, oilproof ones. If you can find an auto parts store with a good selection of air conditioning O-rings (often green or blue) you can usually find the sizes you need.
    • Agree Agree x 1
    • odcics2
      odcics2 Well-Known Member
      122
      7
      Jul 30, 2013
      MoTown
      Local Time:
      9:12 PM
      "dizzy"... lol...
    • dukeboy_318
      dukeboy_318 Get off my lawn!!! FABO Gold Member
      20,706
      5545
      Jan 19, 2007
      la la la la
      Local Time:
      9:12 PM
    • cdnEHbody
      cdnEHbody Well-Known Member
      297
      58
      Oct 24, 2015
      regina sask canada
      Local Time:
      8:12 PM
      Be aware, dorman chevy ones are close, but not quite the right size...leaky!
    • halifaxhops
      halifaxhops 1st instigator, Wives hate me everywhere! FABO Gold Member
      35,802
      7525
      Jan 20, 2014
      CENTRURAL, PA
      View My Photos
      Local Time:
      10:12 PM
      there ARE TWO SIZES ON 1/8 AND THE OTHER 3/32 you can tell by the grove size one is wider, the bigger o ring will fit but you will prob have a ground issue.
    • gdizzle
      798
      85
      May 25, 2015
      los angeles
      Local Time:
      8:12 PM
      Great info guys. So right now I have a big thick (hardened) Oring which presses up against the hold down strap. Then on the shaft there is a groove, and in that groove sits a very thin oring, much thinner than the groove itself. I have never seen colored O rings at the Auto store, just the black ones. I have never seen any oil on the Large O ring, nor have I ever seen any oil leak from the distrib.
    • 89.Fifth
      89.Fifth Member
      12
      2
      Jun 10, 2016
      New York
      Local Time:
      9:12 PM
      I used a very careful application of black RTV and made a contour shape using my finger to get the Dist to seal properly. Let it dry unmounted first and then install. No issues 10 years later.
    • nm9stheham
      nm9stheham Well-Known Member
      7,716
      1049
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      9:12 PM
      Air conditioning sealing O-rings are normally lighter colors.
    • BillGrissom
      BillGrissom Well-Known Member
      6,886
      224
      May 10, 2009
      Sacramento
      Local Time:
      6:12 PM
      Standard black O-rings are termed "nitrile" or "Buna-N". It resists oil, but not gasoline. Turns hard over time with enough heat. AC type are HBNR and come in various colors (grn, red, blu) though trying to standardize on green. They are tougher and handle heat better and I think are better than nitrile for most all applications. Viton are usually dark brown. They resist gasoline and last longer than nitrile. They cost more and are hard to find in larger sizes. Harbor Freight sells kits for each type (english & metric for nitrile). Your life will be easier if you buy each kit.
    • slantsixdan
      slantsixdan =..=
      5,780
      824
      Jan 7, 2007
      Vancouver BC
      Local Time:
      6:12 PM
      Nix on the Harbor Freight suggestion. I'm sure they do sell different-color O-ring kits claiming to be various different materials, but in reality everything they sell is Chinese garbage that doesn't come close to being what it claims to be. Do yourself, your wallet, and your cars a big favor and don't slog through that sewer.
      • Agree Agree x 1
      • BillGrissom
        6,886
        224
        May 10, 2009
        Sacramento
        Local Time:
        6:12 PM
        I guess someone could run a test, soaking the Harbor Freight "viton" and "nitrile" O-rings in gasoline for a month. Seems I recall seeing where someone did that. I doubt they misrepresent the product and most HF products I bought have served well and most I would never have bought at Snap-on prices. Re Chinese, I bought 1/8" viton tubing for my M-B diesel injector return hoses off ebay. It has held up fine for over a year and I use bio-diesel (Propel HPR) which is more aggressive. It seems to truly be viton since everyone who has tried regular black vacuum hose (nitrile) found it swells in a week, even w/ regular diesel, and I saw that when I tried a little silicone hose "just to verify".
      • Charrlie_S
        Charrlie_S Well-Known Member
        2,047
        148
        Oct 17, 2005
        Silver Springs, FL
        Local Time:
        9:12 PM
        • Agree Agree x 1
        • halifaxhops
          35,802
          7525
          Jan 20, 2014
          CENTRURAL, PA
          View My Photos
          Local Time:
          10:12 PM
          I am lost on the o ring by the hold down clamp, between the plate and the distributor?
        • halifaxhops
          35,802
          7525
          Jan 20, 2014
          CENTRURAL, PA
          View My Photos
          Local Time:
          10:12 PM
          hmm NEVER EVEN NOTICE THIS, EARLY DIST? @slantsixdan ? Don't think I ever came across a core with it usually just the small one.
        • halifaxhops
          35,802
          7525
          Jan 20, 2014
          CENTRURAL, PA
          View My Photos
          Local Time:
          10:12 PM
          A member I think here did a great thread on different fuses and when they they actually blew, some were way out of specs, really scarry.
        • slantsixdan
          slantsixdan =..=
          5,780
          824
          Jan 7, 2007
          Vancouver BC
          Local Time:
          6:12 PM
          That thread is here. Also see here.
          Halifaxshops, it's probably staring me in the face, but what are you asking me to notice about one or the other distributor in your pic, aside from one having and one not having the large O-ring?
          Anyhow:
          Chrysler P/N for the top O-ring is 2095 740, discontinued, and the inner diameter is 1.068". Buna-N is an acceptable material. Find it around as a "size 121 round O-ring", such as here (a hundred of them for under ten bucks) or here (one for 35¢, but shipping will probably make it more worthwhile getting the 100-pack, then when the end of the world comes you'll be prepared).
          Chrysler P/N for the bottom O-ring is 2095 630, discontinued, and the inner diameter is 0.920". I'm pretty sure it's a size 021 square O-ring such as this (where you can also read about Buna-N material's characteristics), though it's been long enough since I scrutinized one of these that my recollection of them as square-section could be wrong—they might well start out as round and the outer diameter gets squished flat with pressure, heat, and time. Also possible it's an 020-size ring (outer diameter 1.004") or an 022-size ring (outer diameter 1.129").
          These size numbers apply whether you're getting round- or square-section O-rings, so google searches are easy.
        • Killer6
          Killer6 Well-Known Member
          1,815
          470
          Mar 9, 2015
          PA
          Local Time:
          8:12 PM
          There are many different colored o-rings, but they aren't part of a std. "kit". Some are different materials for different temp. & fluid compatibility, others are coated to help
          ease of assembly. Look at some stock applications like fuel line quick connect fittings, they often have a mix of black,brown, or yellow o-rings. The yellow ones are almost
          always the "back-up" ring, i.e. the first one You see inside, but the second one fuel would see trying to leak, that yellow is a coating that will come off if You try. A/C ones
          can be green, blue, orange(also used in water fittings, and vapor/intake fittings), primarily green....and it is a coating to ease slipping the connections together.
        • halifaxhops
          35,802
          7525
          Jan 20, 2014
          CENTRURAL, PA
          View My Photos
          Local Time:
          10:12 PM
          Dan, Just I don't actually remember seeing that large O ring, is it just certain applications?
        • slantsixdan
          slantsixdan =..=
          5,780
          824
          Jan 7, 2007
          Vancouver BC
          Local Time:
          6:12 PM
          Every Slant-6 distributor needs one large and one small O-ring, and that's how every Slant-6 distributor was factory-installed, from the first one in 1959 to the last one in 1987. O-ring part numbers stayed the same that whole time, too.
        • halifaxhops
          35,802
          7525
          Jan 20, 2014
          CENTRURAL, PA
          View My Photos
          Local Time:
          10:12 PM
          Seriously don't think I ever had a core with one, thanks have to get some then.
        • gdizzle
          798
          85
          May 25, 2015
          los angeles
          Local Time:
          8:12 PM
          thanks for all the comments. Update: So I took the old Oring down to Oreilys, the Dorman selection had 1 opened pack of Misc Orings, supposed to be a 12 pack of assorted, there were 4. There was also a special "Distributor" package with 6 oRings, some black and some Tan. Those were too small. So I went to the counter to complain about the lack of Oring selection, when he pulled out a red case , opened it and there was a nicely laid out selection of Orings. I found the right one (a little thinner than what I had, but the right size), he rang me up $2.20...for 1 oRing. Installed and no leaks.
