looking for 360
Discussion in 'Small Block Mopar Engine' started by ThatMatteBlackDart, Sep 13, 2017.
  1. ThatMatteBlackDart
    ThatMatteBlackDart Member
    9
    1
    Jan 5, 2017
    Temecula, CA
    Local Time:
    12:11 PM
    Hi everyone! I am currently searching for a 360 engine to put into my 68 dart. The car currently has a slant six so I was wondering if someone could recommend where to get a motor and any advice when I do the actual swap. Thank you all so much and hope you all have a great day.
  2. diymirage
    diymirage HP@idle > hondaHP@redline FABO Gold Member
    11,004
    3233
    Oct 12, 2012
    michigan
    Local Time:
    3:11 PM
    sounds like a plan
    you need a few more things though, motormounts, a transmission, a driveshaft (or your shortened) and perhaps a longer throttle cable and kickdown linkage
  3. Dartswinger70
    Dartswinger70 Well-Known Member
    955
    207
    Sep 20, 2005
    A train bound for nowhere
    View My Photos
    Local Time:
    3:11 PM
  4. Dartn440
    Dartn440 FABO Gold Member FABO Gold Member
    2,891
    717
    Jun 2, 2013
    Southern Pines, NC
    View My Photos
    Local Time:
    3:11 PM
    PM sent
  5. rumblefish360
    rumblefish360 so close yet so far away
    29,559
    2554
    Jun 21, 2005
    New York, on a Island
    View My Photos
    Local Time:
    3:11 PM
    Chrysler/Fiat isn't doing any more parts so I'd call the MP shop first to see if the actually have it and can touch it. I myself would rather build my own. And do.
    Schumacher creative services.com For swap kits and lots of info. You will also need;
    A small block transmission
    (Use the same transmission series you have now. 904/727)
    The proper converter. 360's are externally balanced
    IF you have the 7-1/4 rear, make a plan to swap in the 8-1/4 or the 8-3/4. The smaller rear is plenty tuff and a hell of a lot cheaper FWIW After rear end swap, you'll need to shorten the driveshaft.
    A (new) bigger radiator is a huge help.
    I went to summit
    TTI has exhaust for there own headers or the exhaust manifolds you may have all ready.
    Wire strippers/crimpers and some
    Electrical wire to shorten/lengthen engine wires.
    I went to Lokar for throttle cable and trans kick down. EZ to do.
    • Agree Agree x 1
    • AJ/FormS
      AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
      11,398
      1987
      Jan 19, 2014
      Southern Manitoba,Canada Mosquito-land,900ft
      View My Photos
      Local Time:
      2:11 PM
      If it was me, and looking for a drop-in, I'd be shopping for a Magnum. And if you're going for performance, I'd grab an A500 too. Then you can finally run those 3.91 s
      Of course a 318 Magnum is no slouch either, so you can get a teener/A-500 out of an older Dakota, or a 360/A-518 out of a Durango. Neither of those transmissions will fit tho without modding the tunnel. Trailbeast has put one in, and I think he has a thread on the how-to.He makes it sound easy.
    • Shamrock--WV2NC
      Shamrock--WV2NC Well-Known Member
      118
      24
      May 8, 2016
      Mooresville NC
      Local Time:
      3:11 PM
      Good question. Finding a la360 isn't easy. I've looked. Found 2. One wouldn't turn over. The other was not worth the trouble.
      I've looked into 5.9magnums and anything under 150k is over $750.
    • ThatMatteBlackDart
      9
      1
      Jan 5, 2017
      Temecula, CA
      Local Time:
      12:11 PM
      Thank you so much! I will be driving this to school so I want power without sacrificing any reliability. Do you have any motors to recommend?
      9
      1
      Jan 5, 2017
      Temecula, CA
      Local Time:
      12:11 PM
      Yes thank you! I am planning on switching to a manual trans of some sort. I am on a budget so where would you recommend buying my setup?
    • rumblefish360
      29,559
      2554
      Jun 21, 2005
      View My Photos
      Local Time:
      3:11 PM
      I really don't know what is available to you on the left coast as over here on the right cost I have 1 - 318
      Engine, 2 - 360 blocks, 3 - 340 blocks collecting dust.
      IMO, "The Best" anything is somewhat objective. It come from the school of hard knocks and no dang money.
      LMAO!!!!
      Knowing what I know now to answer your question, LAMO, that's easy,
      360, LA or 5.9. The differences are small and not worth splitting hairs over at all. You just have to be aware of them. And then build accordingly.
      Someone will for sure! Pop in and argue for 1 while the next person in line will argue for the other. Don't bother. Get one and go for it.
      Now, again, as before, since I read drive to school and be reliable, find a running 5.9. Even better if you find it in a 2 wheel drive truck as to pirate the OD trans. Because with the OD trans, you can back off the cam timing and run quick while still getting some decent mileage.
      It's a no brainer for me here.
      That's what I would do in an instant.
    • diymirage
      11,004
      3233
      Oct 12, 2012
      michigan
      Local Time:
      3:11 PM
      So...your gonna need an engine, a tranny, a trannyhump, a driveshaft, a pedal assembly...
      If it were me, I'd look for a duster out beaker with the driveline you want and pirate that, then part out the rest to recoup some money
    • Shamrock--WV2NC
      118
      24
      May 8, 2016
      Mooresville NC
      Local Time:
      3:11 PM
      Where does one find a good la360? I'm curious to that myself
    • TrailBeast
      TrailBeast Slightly Twisted Member
      17,135
      3335
      Mar 11, 2011
      Arizona
      View My Photos
      Local Time:
      1:11 PM
      Don't know if it will help you any being out here, but I saw what looked like a pretty nicely built 360 in the Phoenix Craigslist the other day.
      KB pistons, milder side performance cam and I think it was in the 2k range.
      For that it might be worth the 10 hr round trip on I10.
    • Dartn440
      2,891
      717
      Jun 2, 2013
      Southern Pines, NC
      View My Photos
      Local Time:
      3:11 PM
      I have several. Two at machine shop for full machine work. Also have trans to build with 727 or 904.
    • HankRearden
      HankRearden Member
      16
      3
      Sep 11, 2017
      PA
      Local Time:
      3:11 PM
      5.9 magnums go for 150-300 in western PA. They have better heads and a roller cam. Stuff we dreamed about on the LA's back in the day.
      Ive done multiple small block swaps on a bodies. You can use shumacher mounts but I prefer a later model LA spool mount k member and steering linkage myself. A v8 throttle cable from any parts store. Trans for an LA. Use a kickdown cable instead of teh linkage for easy installation.
      I also prefer the HEi ignition. There are units from 60 bucks imported to 300 for MSd.
      • Like Like x 1
        9
        1
        Jan 5, 2017
        Temecula, CA
        Local Time:
        12:11 PM
        That sounds like an awesome idea actually I was looking to put around 350 to the wheels so I was unsure if a stock powertrain would hold up
        9
        1
        Jan 5, 2017
        Temecula, CA
        Local Time:
        12:11 PM
        Do you have the link for that motor?
      • rumblefish360
        29,559
        2554
        Jun 21, 2005
        View My Photos
        Local Time:
        3:11 PM
        It will
      • TrailBeast
        17,135
        3335
        Mar 11, 2011
        Arizona
        View My Photos
        Local Time:
        1:11 PM
        I looked up Mopar on craigslist (Phoenix)
