Very few 426-S Mopars were found at the Drag Strip after 1969.
Complete Specifications on Post #17
The Carter AFB {575 CFM} for the 426 Street-Wedge was woefully under-sized.
* Plymouth ------------1964 Belvedere {Sedan} ------ 1968 Road Runner {Pillared Coupe}
* Engine ----------------- '426' Commando --------------- Road Runner 383
* Shipping Weight -------- #3347 lbs. --------------------- #3422 lbs.
*Weight-to-Horsepower --- 9.17 --------------------------- 10.22
* Bore................................ 4.25"...................................... 3.75"
* Stroke............................. 3.75"...................................... 3.38"
* Compression Ratio......... 10.3 - 1 ................................. 10.0 - 1
* Advertised HP............... 365 HP @ 4800 RPM's ........... 335 HP @ 5000 RPM's
* Advertised Torque........ 470 Ft/Lbs. @ 3200 RPM's .... 425 Ft/Lbs. @ 3400 RPM's
* Engine Dyno HP ........... 315 HP @ 4700 RPM's ........... 310 HP @ 5000 RPM's
Drag Race Test
Both cars equipped with;
* 4-Speed Transmission
* Hurst Shifter
* 3.91 Gears w/Sure-Grip
* Cheater Slicks {7" Width x 28" Tall}
1st Gear
Despite being {+75 lbs.} heavier, the Road Runner would get off-the-line first.
The 383 gains the advantage because of the shorter engine stroke, and quicker RPM gain.
The '426 Street Wedge' was notoriously sluggish coming out-of-the-hole.
The Road Runner would jump out to a '3/4' car length lead thru 1st-Gear.
But, by the end of 1st-Gear, the bigger 426 engine {+43 cubic inches} would start to make it's move.
2nd Gear
Advantage for the 426-S 'Street Wedge', as this engine had 'strong' Mid-Range Torque.
Once the RPM's got up in the Engine, the 426-S would start to breath, and catch the 383 {shorter stroke}.
By mid-way thru 2nd-Gear, the 426-S would pull 'even' with the Road Runner 383.
And, by the end of 2nd Gear, the 426-S would have a 'slight lead'.
3rd Gear
The 426-S would add to it's 'advantage' thru early 3rd-Gear, and continue to pull on the Road Runner 383 by
mid-way thru 3rd-Gear.
The 426-S {+43 Cubic Inches} would extend it's lead to a full car-length by the end of 3rd-Gear.
4th Gear
A 'surprise' here. What should be expected, is that the Belvedere 426-S {with +43 Cubic Inches} and longer stroke,
should pull away from the Road Runner 383.
But on 'Top End', the 426-S would starve for fuel, and flatten out.
1} The Carter AFB {575 CFM} limited Air-Fuel mixture.
2} The low-profile Intake Manifold would restrict breathing.
3} Also, the 'weak' Valve Springs would float out at 4800 RPM's.
The Road Runner 383 would make a move, and nearly catch the Belvedere 426-S at the 'Traps'.
1} The Carter AVS {625 CFM} would provide more Air-Fuel mixture.
2} The better design Intake Manifold would provide better flow on Top-End.
3} More Cam {Lift and Duration}, with higher load-rate Valve Springs.
4} Better flowing Cylinder Heads.
5} Better Exhaust System.
This one was interesting. Didn't know that the 426 wedge was a dog off the line. I had the 'Runner taking the win at the top end mostly due to better breathing.
Thanks for distinguishing,between the three,Thank You!
'Econo-Racer' Street Musclecar Match Race
1968 Road Runner {383/335 HP}
* Coupe
* 4-Speed
* 3.91 Gears
* Shipping Weight....... #3422 lbs.
1964 Belvedere {426/365 HP}
* Coupe
* 4-Speed
* 3.91 Gears
* Shipping Weight...... #3347 lbs.
First Hand Experience,
The 1964 Belvedere '426' Commando {Shipping Weight; #3347 lbs.}
Though the '426-S' {365 HP} was over-rated in the HP Department by the Factory, on the street it was consistently good.
* 365 HP @ 4800 RPM's
* 470 Ft/Lbs. of Torque @ 3200 RPM's
And, the 'Sedan' body style was 'stiff-and-rigid'.
Just add Gears and Headers, and the 426 Street Wedge was a top runner on the street.
Comparisons
* Cars ..........................1964 Belvedere 426-S 'Sedan' ........... 1968 Road Runner 383 'Coupe'
* Shipping Weight.......... #3347 lbs. ........................................ #3422 lbs.
The Belvedere 'Sedan' with the '426' Commando is {75 lbs.} lighter.
That would be worth .10 {1/10th} in Elapsed Time.
* Carburetor ............. AFB .................................................... AVS
* Model .................... #3611 ................................................ #4426
* CFM ........................ 575 .................................................... 625
* Throttle Sizes ........ 1.437" x 1.563" .................................. 1.437" x 1.686"
Advantage with the Road Runner. The Carter AVS {625 CFM} provided 'more' fuel than the Carter AFB {575 CFM}.
And the bigger Secondary {1 11/16"} provided more Top-End.
