oops, I failed to read >>> Early "A" ( until after I made the post)
if mounted with outlets to the rear
lots of items in the way > Mainly the firewall Passenger manifold is 3" past the head.
steering column is directly in the way as is the master cylinder
I did this on a 68 Satellite.
on my 72 Dart - to make them fit easier.....
swapped sides-outlets to the front
moved the master cylinder > 3 " toward the outside.
passenger side - reworked the inner shock tower, notched the frame rail
move the alternator to the drivers side
changed water pump to passenger side inlet
custom head pipes
