dirty white boy
50 yr old Juvenal delinquent
will this shift kit work in a 86 model 904? is it worth 50 bucks?
IMO it's not worth $1 and I would not use one. I used one once and it caused such severe overlap between gears that it would have quickly ruined the trans if I hadn't taken it out. Get a Trans-go TF-1 or TF-2 if you want a good shift kit that'll not only make your trans shift firmer but last longer
exactly the info i needed,..thanks!
I hope you got the TFOD-HD2 kit for your 42RH, not the TF2. Different trans, different kit. When the OD Chrysler transmissions first appeared, I contacted Transgo and asked if the TF1/2 would work. Their words of wisdom, yes it'll fit, but no it wouldn't work the way they wanted it to in the OD transmissions. It may have been a marketing ploy (the TFOD-HD-2 kit wasn't available yet), but until the OD kit was on the shelf, we had no kits available for the A500/A518 series.Price around on your shift kit, because for my 42RH the local shop wanted $315.00
I might be ugly but I ain't stupid.
Got the exact same TF2 kit for $115 shipped online.
$315.00?
I think that this kit came from Fairbanks, and no it's not worth $50.00View attachment 1715009842
