MSD
Discussion in 'Small Block Mopar Engine' started by Mopar Tim, Jul 16, 2017.
  1. Mopar Tim
    Mopar Tim FABO Gold Member FABO Gold Member
    10,122
    3811
    Nov 29, 2014
    vista CA.
    Local Time:
    6:25 AM
    Hey guys, I think I have tracked my weird idle problem to the MSD Dist. I seems like advance is coming on too soon, and increasing idle speed, from 1200 to 1800 RPM. 20 degree advance initial, all in at 45 degree. At 1800 timing increases from initial to about 28 degree. MSD Dist, How to change to come in later. Thanks. No Vac. Just a little, it is right on the edge of being great. Maybe tune is the problem, but it starts and runs great, till it gets warm, about 180 Degree. Weird problem. Thoughts? Thanks All
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    25,094
    7235
    Jan 18, 2006
    Iowa
    View My Photos
    Local Time:
    8:25 AM
    Just kinda thinking, stronger advance spring. (just one to start) Almost sounds like it's right on the edge of advance at idle rpm. When things get warmed and the oil gets thinner it picks up a hundred rpm and goes into manual advance. What does it idle at and can you slow it down a few hundred? Might be all it needs.
    • Thanks! Thanks! x 2
    • Mopar Tim
      10,122
      3811
      Nov 29, 2014
      vista CA.
      Local Time:
      6:25 AM
      That is what I think as well. But does not the MSD Dist. have another way to limit when centrifugal advance comes in? I am right near perfect on the tune, idle speed seems to be perfect, other then it increases like I posted. Cold idle is 1000, no choke. as it warms up, 1200. Gets hot,180 degree, goes up to 1800. Still runs great no matter the temp.
    • toolmanmike
      25,094
      7235
      Jan 18, 2006
      Iowa
      View My Photos
      Local Time:
      8:25 AM
      I'm not the guy to ask. I don't know much about MSD other than all I hear about MSD is a announcement over the loud speaker at the drag strip that someone needs a 6al box! LOL
      • Like Like x 2
      • Mopar Tim
        10,122
        3811
        Nov 29, 2014
        vista CA.
        Local Time:
        6:25 AM
        :rofl:
      • abodyjoe
        abodyjoe Well-Known Member
        18,298
        2188
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        9:25 AM
        heavier spring should fix it... doubt you need full timing so early.
        • Like Like x 1
        • Thanks! Thanks! x 1
        • Mopar Tim
          10,122
          3811
          Nov 29, 2014
          vista CA.
          Local Time:
          6:25 AM
          Thanks....
        • Mopar Tim
          10,122
          3811
          Nov 29, 2014
          vista CA.
          Local Time:
          6:25 AM
          Ordered the spring kit from summit. :thumbsup:
        • downsr
          downsr FABO Gold Member FABO Gold Member
          841
          460
          Dec 17, 2011
          waverly ohio
          Local Time:
          8:25 AM
          Set your idle at 1000 rpm when its hot, your spring kit will show you when advance starts on a graph for each set of springs. I use 1 heavy silver and 1 light silver springs with idle at 1000 rpm hot
          • Mopar Tim
            10,122
            3811
            Nov 29, 2014
            vista CA.
            Local Time:
            6:25 AM
            Got spring kit yesterday, will install as @downsr suggesred^^^^
          • abodyjoe
            18,298
            2188
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            9:25 AM
            look at the instructions that came with the springs and see where that is gonna bring total in at.. it may or not be good for your combo. the springs go hand and hand with the bushings..
            any idea what bushing you are running?
            1 heavy silver and 1 light silver can bring total timing in anywhere between 3000 and 4000 RPM depending on what bushing you are running.
            https://static.summitracing.com/global/images/instructions/MSD-8464_frm28727.pdf
          • Mopar Tim
            10,122
            3811
            Nov 29, 2014
            vista CA.
            Local Time:
            6:25 AM
            Have not disassembled it yet, Thanks for advice..:thankyou:
          • downsr
            841
            460
            Dec 17, 2011
            waverly ohio
            Local Time:
            8:25 AM
            I am running a 18 degree bushing and setting the initial timing at 18 degrees which gives you a total of 36 degrees at 3000 rpm
          • Mopar Tim
            10,122
            3811
            Nov 29, 2014
            vista CA.
            Local Time:
            6:25 AM
            I am initial at 20 degree and total at 40, so I will need some calculations...
          • Mopar Tim
            10,122
            3811
            Nov 29, 2014
            vista CA.
            Local Time:
            6:25 AM
            Well crap, it has the 2 heavy silver springs already in it. And the silver bushing. Any ideas?
          • Mopar Tim
            10,122
            3811
            Nov 29, 2014
            vista CA.
            Local Time:
            6:25 AM
            Leaving in the 2 heavy silver springs, turned the initial to 35 degree and installed the purple stop bushing.
          • B3RE
            B3RE B³ Racing Engines
            347
            181
            Aug 22, 2013
            USA
            Local Time:
            9:25 AM
            You really shouldn't need 40+ degrees of total timing unless the CR is low with aluminum heads. You could very well need more initial advance. I have bushings that shorten the mechanical advance to 10 or 14 degrees. The best you can get with the MSD kit is 18.
            • abodyjoe
              18,298
              2188
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              9:25 AM
              what the hell is this motor? why do you need 35* initial?
              most of my small block stuff i usually run 17-20 initial and about 35 total.. in by say 2400rpm
              • Like Like x 1
              • Agree Agree x 1
              • toolmanmike
                25,094
                7235
                Jan 18, 2006
                Iowa
                View My Photos
                Local Time:
                8:25 AM
                Cam timing not correct?
                • Like Like x 1
                • Disagree Disagree x 1
                • Mopar Tim
                  10,122
                  3811
                  Nov 29, 2014
                  vista CA.
                  Local Time:
                  6:25 AM
                  It is just alot of engine to be running on the street. 408 stroked over 500 HP and Torque. The Cam shaft is a custom grind, I really need to change the converter. Too tight,
                • Mopar Tim
                  10,122
                  3811
                  Nov 29, 2014
                  vista CA.
                  Local Time:
                  6:25 AM
                  Engine was built by a reputable builder and Dyno'd. Im sure the cam is installed correctly. The engine runs great, like said, I should swap the converter.
                • Mopar Tim
                  10,122
                  3811
                  Nov 29, 2014
                  vista CA.
                  Local Time:
                  6:25 AM
                  You sell those bushings?
                • crackedback
                  crackedback FABO Gold Member FABO Gold Member
                  17,478
                  1356
                  Aug 7, 2005
                  92201
                  Local Time:
                  6:25 AM
                  You have to have a spring set up that holds the weight static at idle. Once it starts bleeding in advance it usually runs a bit more rpm and keeps running away.
                  I'd run something at least 24* initial with a 10* bushing and see what happens. Should help with the idle running up.
                  • B3RE
                    347
                    181
                    Aug 22, 2013
                    USA
                    Local Time:
                    9:25 AM
                    Yes, pm for details.
                  • downsr
                    841
                    460
                    Dec 17, 2011
                    waverly ohio
                    Local Time:
                    8:25 AM
                    You are running to much total timing.I have a 416 500hp 570 ft lbs of torque with a custom camshaft.Total timing 36 runs and idles great.
                    I think you should set the timing like i said or the way cracked backed suggestion which i have also used and leave it alone and start looking elsewhere for your problem.I put a 2 brand 650 holley double pumpers on mine and the idle acted like your are describing.Ended up with a 670 holley with no more problems.Looking back the pcv system was affecting my idle circuit
